car stalling under hard braking?
Old Jun 23, 2002 | 10:05 AM
mike89z's Avatar
Car: 89 Iroc-Z
Engine: 355
My car tends to stalls everyonce and a while when I panic stop and I was wondering if it could be something that I could change in the chip. A little background; mods to car listed below, Ive gotten the chip so that the BLMs are within 124 - 128 so I think Im pretty good there, and the IAC counts are only like 30 so I dont think that has anything to do with it. The idle right now is set to 750 and I was wondering if bringing the stall saver spark up to 675 from 550 would help and how much spark does each threshhold have.(there are 3). Just my thoughts and I would like anyones on the subject. Thanks
Old Jun 23, 2002 | 01:59 PM
slowTA's Avatar
Car: '88 Formula
Transmission: T-5... in need of slight rebuild
When I first converted to TPI it would stall whenever I came to a stop from moderate cruising. Turns out the minimum air wasn't adjusted correctly. When the motor would come down to idle the IAC couldn't react fast enough to keep the motor running.
Just a simple suggestion... also if the oil pressure drops alot the fuel pump will cut out.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Wade787b
Sep 29, 2015 01:15 PM
kyleb24
Aug 15, 2015 08:24 AM
TreDeClaw
Aug 14, 2015 06:58 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
