Need known good 305 TBI 5spd 8746 bin
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
I need a known good stock 305 TBI 5 speed 8746 BIN file for comparison to the stock automatic version.
THANKS,
Brian
THANKS,
Brian
ftp.diy-efi.org
go to the gmecm/bin_lib section and look up the 746 ecm and you should be able to find what you need. I cannot say which bin will be for a 5 speed or if the one you need will be there but that is probly the best place to start
Brendan
Brendan
I know I can get it there but I have NO idea what CODE the 5 speed L03 is. I know that ANLU is the 350 L05 Cop car automatic chip but that is about it. I would have to go out and pull my ECM to tell you what the code is on my L03 Automatic.
So if someone can give me a valid code for L03 5 speed that would be fine too.
I ran into a similiar problem looking for the manual 730 chips , I just downloaded all of the ones from the ftp then look at the switches and torque convertor settings, the manual chips won't have any TCC settings... I guess thats one way.
Go to this link and look at the engine, induction, exhaust Q&A and it lists all the years, and the code for each car. You'll find what you need there.
https://www.thirdgen.org/newdesign/faq/thirdgen.shtml
They were all TPI cars. None listed the 8746 ECU.
Thanks for the info. I downloaded the code and have been comparing the 2. THANKS.
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
Sorry for the ignorant question, but I can't find any application to open those files. What do you guys use to open them?
I use Tunercat with the $61 definition file. You can find out more about Tunercat and such in the chip programming tech article in the tech section of this site. https://www.thirdgen.org/newdesign/tech/promintro.shtml
My bad. Yeah, I used the AXKW in my 88 sc with the 305tbi and 5 speed and 8746 ecm. It worked pretty good. Sorry about the goose chase.
