Why isnt my PP2 working?
Old Aug 3, 2002 | 04:43 PM
Chris Etemadi's Avatar
Car: 1991 Z28
Engine: 5.3 Gen III SBC
Transmission: 4L80E NTC 258mm Stall
Axle/Gears: Trick Chassis 9" 3.50 S-Strac
I just recived it today. I plugged everything in.(power source, and into the LPT1 printer port. When I run the software it comes up with a error box saying :
"The Pocket Programmer cannot be found on LPT1, LPT2, or LPT3
Make sure your power pack is plugged in."
I click "OK" the only option
and in the yellow highlighting it says The power programer was not found.
What could I have done wrong? maybe this is a faulty unit?
BTW Im using Windows 98
Thanks, Chris
Old Aug 3, 2002 | 05:14 PM
funstick's Avatar
try using the hardware add in the control panel. could be yr compter doesnt see it.
Old Aug 4, 2002 | 02:35 AM
Car: 1991 Z28
I tried everything it seems. Im really anxious to get it going so I can learn what I am doing. has anyone had the same problem?!?!
Old Aug 8, 2002 | 12:43 PM
Car: 1991 Z28
TTT
Old Aug 8, 2002 | 06:37 PM
TPI K5's Avatar
make sure the AC adapter is plugged in.
Old Aug 9, 2002 | 06:22 AM
Car: 1991 Z28
I did. I tried different outlets just incase, I have also blew out the LPT1 port with compressed air. still no luck. Are these prone to be faulty? I think Im going to try it on a friends computer towmorrow.
Thanks, Chris
Old Aug 9, 2002 | 01:27 PM
86Red4+3's Avatar
I've had one for about a month and it did that several times. I found that with the computer on, if I unplug the PP2 and plug it back in, then start the program it gets recognized. So now I just leave the PP2 plugged in all the time and the problem hasn't appeared even though the computer gets shut off daily. This is a desktop unit running windows. I can't get it to hook to my DOS laptop no matter what I try (unplug trick, all possible port settings, etc), so I have to do all my burning in air conditioned comfort
Old Aug 9, 2002 | 11:02 PM
S10Wildside's Avatar
Me Too!
I'm sorry to hear about your PP2, but I'm glad to know you're having trouble, too!
I just got my PP2 about a week ago and it will NOT work. I messed around with the CMOS settings for the port, and just about everything else under the sun to get my computer to recognize it. I get the exact same error message as you on my Windows XP machine and my parent's Windows 2000 machine. I even downloaded the latest software.
I wonder if something is bad with a recent production batch of these programmers. I called about this, but no one will be back at Xtronics until after the 15th of August.
Please keep me posted with your progress in this issue!! I want to start messing around with my PROM, too.
Feel free to email me... mdn124@psu.edu
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
