FT Cell
Old Nov 6, 2002 | 11:22 PM
justme's Avatar
FT Cell
What exactly is FT Cell and how is it determined? I logged some data today and noticed the FT Cell stayed on 4 the whole time. Is this supposed to change? Also, is Startup Enrichment Vs. Coolant Temp used until engine reaches closed loop? I am having a very rich problem on the mornings it is 30F or 40F degrees outside.
Old Nov 7, 2002 | 12:21 AM
funstick's Avatar
care top explaine what type of car ecm and scan tool your using ?
Old Nov 7, 2002 | 08:14 AM
justme's Avatar
It is speed density 730 ECM TPI in my jeep. I am using a snap-on MT2500 scanner.
Old Nov 7, 2002 | 10:35 AM
funstick's Avatar
well then you should have the BLM and INT. the FT is most likely just a rich/lean counter.
Old Nov 7, 2002 | 10:42 AM
justme's Avatar
when I first started it up the BLM and INT stayed at 128 and it runs like crap. Really sounds like it is loading up. What do I adjust for cold start mornings. I am not worried about the FT cell if it is not important I just wondered what it was for.
Old Nov 7, 2002 | 11:30 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
When you first fire up you are in open loop and the BLM/INT will be at 128/128 till it goes into closed loop.
FT Cell is "fuel trim cell". I have heard it is normal for it to stay "4" all the time.
Old Nov 8, 2002 | 11:35 AM
funstick's Avatar
proboaly change to a/f ratio in open loop vs coolant temp would be my first geuss.
Old Nov 9, 2002 | 07:04 PM
justme's Avatar
isn't the (percent change to air/fuel ratio in open loop) at idle only? It will idle fine upon startup but with a small amount of acceleration it loads up and stumbles and you have to floor it to clean it out. Once it warms up a little it has no problems at all.
Old Nov 9, 2002 | 11:49 PM
funstick's Avatar
you so sure its not leaning out ??? try adding a bit of fuel when cold to the AE values.
codeysabatini
Nov 10, 2015 04:07 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Chevykid810
Sep 28, 2015 12:57 PM
3.8TransAM
Sep 27, 2015 08:37 PM
ULTM8Z
Sep 16, 2015 09:15 AM
