vss?
Old Jan 10, 2003 | 07:20 PM
btcamaro's Avatar
Car: 91 Camaro
Engine: 383
vss?
I was wondering if i change rear end gears do i need to change the speedo gears at the tranny or can you just change the road speed constant in the prom to correct the speedo reading for the ip cluster.
Old Jan 10, 2003 | 07:54 PM
funstick's Avatar
ahh which ecm ?
Old Jan 10, 2003 | 08:32 PM
btcamaro's Avatar
Car: 91 Camaro
Engine: 383
sorry it is the 7730 ecm.
Old Jan 10, 2003 | 08:39 PM
funstick's Avatar
what kinf of car ?which code mask
Old Jan 10, 2003 | 08:45 PM
btcamaro's Avatar
Car: 91 Camaro
Engine: 383
91 camaro with $8d mask
Old Jan 10, 2003 | 09:23 PM
funstick's Avatar
have you checked the diagrams over at the gmecm at diy-efi.org site. there schematics i dont have time top puruse them myself. but if it has a vss input and a dash vss output then you could just the input pulse counter to arrive at the correct dash speed. go look at the schematics let me know whats in there. and maybe traxion will pop in and lend some $8d know how.
Old Jan 14, 2003 | 07:21 PM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Re: vss?
There's info here on changing it for a T56,
but it may be less complex on a T5 w/gears...
http://www.eecis.udel.edu/~dzug/92z2...0-vss4T56.html
mike
Old Jan 15, 2003 | 10:02 PM
SMasterson's Avatar
Car: '89 GMC Pickup
Engine: 383 SBC Stealth Ram
Transmission: 700R4/VIG 3200
With Tunercat you can change the Road Speed Constant in the ECM Constant Tables to get the ECM to read the actual speed but the speedometer will still be off unless you change the gears to match. From 3.08's to 3.73's I went from 4007, which is what every binary file I've viewed was set at, to 5453 to get the ECM to calculate the correct speed.
There is also a Instrument Panel Vss Pulse Divisor but changing that only got me a speedometer that didn't work at all. I'm not sure what it does.
There may be a way to edit the binary file to get the speedometer correct too but I didn't. Just called a GM dealer and they sold me the correct gears.
$750 L98
Feb 1, 2025 02:25 PM
GTAman
Jul 3, 2024 07:29 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
