Dell Laptop issues...
Old Jan 31, 2003 | 10:36 AM
SCCAjunkie's Avatar
Car: 84 Z28
Engine: 91 L98 long block with Pro-jection
Axle/Gears: 91 10bolt w/ 3.42s and T2R
I'm not sure if this is the correct place to ask, but you guys are basically my last hope.
I have a Dell Latitude CP (P233), and I cannot get it to work with my ALDL adapter. I have determined the adapter is good (works on other laptop and desktop), and I have figured out the situation with the port itself- It will recieve but not transmit. When I attempt to sync my Palm, it will recognize it, but not transfer because it doesn't handshake. If I bring up HyperTerminal, it will recieve a string of data, but if I shunt pin 2 to pin 3 (9pni connector) I get nothing back when I try to send.
Norton System Works and Dell Diagnostics programs both tell me the port is fine, and it passes all the loopback tests.
Also, I have a dock, and the serial port on that behaves the same.
I am thinking this is software/driver related, but I have tried many different settings to no avail (changed COM settings in Bios, screwed with output addresses a little).
Has anyone had a similar problem? Did you ever get it fixed? Does anyone have a serial-PCMCIA adapter card I could try?
HELP if you can at all, I grasping at straws here...
Thanks so much, I already owe alot to you guys, and I want to start contributing, but I am ready to take this thing airborne at this point...
:lala:
Old Jan 31, 2003 | 11:53 AM
Morley's Avatar
Have you tried disabling the IR port in the BIOS?
Old Jan 31, 2003 | 04:29 PM
SCCAjunkie's Avatar
Car: 84 Z28
Yup, tried that. Even tried disabling the parallel port too...
I'm just screwed, aren't I?
Old Jan 31, 2003 | 08:12 PM
Morley's Avatar
It really sounds as if the serial port may be dorked up.
Old Feb 3, 2003 | 01:16 PM
gelbza@yahoo.co's Avatar
Just wondering what software you're running. I had the problem of not being able to get Freescan to connect on a Latitude LM, and finally ended up switching to Datamaster and it works fine. Plus, I like Datamaster's interface better, not to mention that it's designed for my car specifically, rather than being sort of bastardized from a Lotus program. Just my opinion, but worth trying.
Old Feb 3, 2003 | 06:26 PM
SCCAjunkie's Avatar
Car: 84 Z28
I haven't even gotten to the software, because the port won't work at all in anything...
Anyone???
Does anyone think a PCMCIA serial port card will help me?
Old Feb 3, 2003 | 07:30 PM
funstick's Avatar
without some scanning software the ECM wont send info. you have to send a handshake pakcet to enable cummunicatios. get some software and try running something like freescan or the moates software. you cant mae a p4 chat without waking up the ecm itself. if yoy think its a port issue what OS are you running i had trouble with win95 and winxp i am runnign either win98 or winME. they both work fine with the dell softwre.
Old Feb 3, 2003 | 07:35 PM
badbwti's Avatar
Hi everyone, this is my first post so if I'am doin this wrong, please correct me. Now, for my reply, I have basicaly same computer and HAD same problem. What fixed mine was simply removing my com port in device manager and rebooting computer. I have to do this everytime I want to use my cable.
gta892000
Sep 16, 2015 12:40 AM
CORV3TT3
Aug 23, 2015 11:26 AM
fbodymike
Jul 16, 2001 11:15 AM
MrDano
Jul 5, 2001 06:38 PM
jRaskell
Dec 30, 2000 12:33 AM
