A few Q's about Diacom
I'm using diacom to read my sensor data, and after logging about 100 points or less, it freezes up on me. Does anyone have experience with this situation? Even without doing a data capture and simply monitoring my sensor data it freezes on me.
Also, during different data captures within a few minutes of each other my BLM's are different:
ie one data capture has RPM 2000 MAP 40 BLM 118, then a few minutes later i get RPM 2000 MAP 40 BLM 140.
Can anyone help me.
Can anyone help me.
What os are you using? And just to check-you are using diacom from dos? Not just a dos window?
As for the blms-have you put a few miles on it? And when the blms are diff. for the same rpm/map-are the cells the same?
Car: An Ol Buick
Engine: Vsick
Originally posted by Astro
im using dos 6.0, and yes im lauching it from dos, not a shell.
If on a floppy install it to the HDD and repeat.
Car: An Ol Buick
Engine: Vsick
its on the hard drive. Its just really annoying.
I had an IBM laptop at one time that it wouldn't work on. Dunno what else to tellya on that one.
