Craig Motes software and my car????
Old Mar 5, 2003 | 08:09 PM
FIRECHICKEN's Avatar
Car: '89 Formula 350
Engine: 5.7L L98 TPI
Transmission: 700-R4 Automatic
Axle/Gears: 7.5 disc posi 3.23
Need help with Craig Moats Software and my car. I am in the very beginning stages of scanning my car. I hooked my laptop to the car with an AKM cable and Craig's software and got nothing. I am probably missed something, but that is why I am writing. I have an HP laptop running windows Milenium edition. I also am running a Hypertech chip in the car currently. Craigs program runs on the laptop but can't link up. I don't get an error or anything I just get nothing. I turned the default setting to online and nada. I do not have the 10K resistor between A and B as suggested but I am assuming it is built into the AKM cable.
So that's what I have. How do I make it work?
Old Mar 7, 2003 | 11:03 AM
87ColdAirIroc-Z's Avatar
Sounds exactly like the problem i had before i had the 10 k resistor between a and b, however i made my own cable, you may want to check with AKM and make sure the resistor is included in the cable, it may not be.
good luck, craigs program is very cool
Old Mar 10, 2003 | 07:08 PM
Come on all you tech guys I need more feedback.
Old Mar 10, 2003 | 08:17 PM
kevinc's Avatar
Car: 1982 Z28
Boot it from a DOS floppy and re-test.
Old Mar 10, 2003 | 09:54 PM
91Z28-350's Avatar
I haven't had problems with Moates software. Have you tried the 12v source? I didn't need it, but maybe you do? Boot from the floppy, as suggested, or if using win9x, boot and hold down the shift key. Is your serial port enabled?
Old Mar 11, 2003 | 08:29 AM
Craig Moates's Avatar
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
I've heard of some people having problems with aftermarket chips, some not. Don't know if this is the issue, just thought it worth mentioning.
Old Mar 11, 2003 | 09:29 PM
87_TA's Avatar
You never answered the first technicians about the resister..
Does you cable have one ,you need that for the MAF cars.
Old Mar 11, 2003 | 09:31 PM
87_TA's Avatar
Oh yeah,my AKM cable did not come with one installed but the left provisions for it. But I did not need cause I just converted to SD right after recieving the cable.
Old Mar 18, 2003 | 12:59 AM
Ovrclck350's Avatar
I'm having problems getting Moates to work on my car too. Datamaster works just fine, I have the black A and the green to the M on my ALDL like the instructions said, but MOates will not link....
Any suggestions?
Old Apr 4, 2003 | 04:53 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
My AKM has the 10k built in (there are 3 wires to hook up. black to A, red to M, and white to B. The 10k is between the black and A in the interface cable).
I haven't had success in getting craigs software to work either, however I can get winALDL to work (however, its 160 BAUD, which is strange - and the update rate [1 per second] sucks).
So, you do need the 10k.
Old Apr 4, 2003 | 06:26 PM
I checked and I do have the 10K resistor. Where do I gat the Win ALDL software previously mentioned?
Anything that will work with Win2000. Also how do I make this DOS bootable disk?
Thanx
Old Apr 5, 2003 | 10:45 AM
Ragtop89's Avatar
Thanx
I sent a email to Craig and he suggested that WIN2K was my problem.
Since I am using an OLD laptop I loaded WIN98 on it and everything works great.
All that's on my laptop is programing and scanning software now.
It's all I'll use it for.
Old Apr 5, 2003 | 11:14 AM
Car: 87 T/A
Sweet...
Old Apr 5, 2003 | 11:40 AM
Ragtop89's Avatar
Originally posted by Craig Moates
Sweet...
:hail:
Thanks big guy!
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
