GMECM Edit Version 2.11 now available
Old Jun 26, 2003 | 04:00 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
Hope you guys aren't tiring of all the GMECM Edit posts. =)
http://gmecmedit.markmansur.com/
Whats New in this version?
- Added inc/dec functionality within summary view ( using numpad +/- or ctrl -/ctrl = which is the same for the editor windows)
- fixed title bar issue when "new ecu" is selected.
- you can now *actually* disable default ecu opening at bin load
- default ecu loads when dragging/dropping a bin into the editor
- "prompt when mask not recognized" works now.
- fixed a number of crashes
I'm going to be digging in deep for some new major functionality in upcoming versions, so stay tuned ...
PS - you may want to delete your old GMECMEditSettings.dat file before running the app. This will clear all saved settings.
Have fun!
M
Old Jul 1, 2003 | 10:52 PM
knoxbonnie's Avatar
Tired???
I look forward to them! YOU ROCK!
BTW, thanks for doing this.
Old Jul 4, 2003 | 09:32 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
Nope. I never get tired of a great program that gets better and better. keep up the good work.
Old Jul 15, 2003 | 09:54 AM
Vader's Avatar
Tired? No. Nice work on the editor.
Just a question - Have you had any reports of GMECM Edit having compatibility issues with AutoCAD 2000i ?
Old Jul 15, 2003 | 10:22 AM
Mangus's Avatar
Transmission: T5WC
Nope. I have AutoCAD 2000 installed myself. No issues.
Not to mention that GMECM Edit uses no resources outside of its own exe. It does not use shared DLL's, libraries, etc. Everything is self-contained. Hence the lack (so far) of an installation routine.
I am curious about this, though. What leads you to believe GMECM Edit (or AutoCAD) would be the culprit?
Old Aug 11, 2003 | 02:10 AM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
Tried em all and I think yours is best to work with. Can't wait for 3D graphs!
Old Aug 11, 2003 | 09:51 AM
Mangus's Avatar
Transmission: T5WC
I've started work on just that and much, much more that you all will very much appreciate. Stay tuned...
Old Aug 11, 2003 | 10:10 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
I'll just be happy with the PROMinator being done and added into your stuff!
Just sending out a thumbs up on your software, of all of them I've played with so far (that's all I've done, no real world usage yet) I'm really liking your's!
Thanks for doing it!
Old Sep 27, 2003 | 08:34 AM
Vader's Avatar
Your .BIN editor is just fine. I had a rather coincidental situation. I had downloaded and installed your editor. I used it a couple of times with no problem. I had also installed a new version of Norton AV 9the whole package. It seems that good old Peter wrote a .dll for NAV 2003 that was incompatible with ACad2000, 2000i, MDT, and a few other iterations of AutoDesk software. Norton didn't do anything to rectify the problem, but there is a "repaired" .dll available at the AutoCad site that fixes the problem. In case you encounter a similar problem, there is good technical support for AutoDesk applications at http://www.cad-1.com/tech_support1.htm
My apologies if my inquiry may have cast doubt on the efficiency and integrity of your software. :hail:
So far, your software seems to be well-engineered. I'm especially impressed with the ability to customize the .ecu files. I think this will be a very powerful tool in helping me crack the old CCC PROMs.
I'm still trying to simulate those occasional shutdowns of the program and capture the exact causes. I haven't been doing a lot of .bin editing lately, but with autumn upon us, it probably won't be too long before I head back to the "cave" and get at it.
Old Sep 27, 2003 | 09:22 AM
JP84Z430HP's Avatar
Car: 84 Z28
Wow! Thanks for the tip Vader! I'm having an issue with MDT drawings becoming unusable, I wonder if this may be it? It did get my butt in gear to work with Inventor, finally, thoung, and I have to say I like it better than MDT.
So, are the newer version of the software (that will work with specific devices!) still gonna be self contained and as simple? That is one thing I like about your stuff!
Old Sep 27, 2003 | 02:27 PM
Mangus's Avatar
Transmission: T5WC
No, I'm glad you brought it up. Things like this are the kick-in-the-pants I need to question my own code, which often leads me to fix other bugs!
In a very short time I will be releasing the next incarnation, with Romulator, AutoProm, and ALDL data monitoring. Oh, and nifty 3D graphs.
GMECM Edit is now called TunerPro.
Look for it very soon.
Mark
Elephantismo
Feb 13, 2019 12:51 AM
3rdgenparts
May 21, 2016 11:50 PM
1992Z28!
Nov 19, 2015 07:33 AM
ramicio
Sep 28, 2015 01:18 PM
cking99
Sep 22, 2015 11:33 AM
