Problem with romulator and '278
Old Jul 6, 2003 | 04:30 PM
rooster433's Avatar
Hello,
i just got my romulator and i'm having problems with it. I can program the romulator when the romulator is not pluged into the car but as soon as it is plugged into the car it will no longer program nor will it verify.
the car will not run with the romulator at all.
Any ideas?
Old Jul 6, 2003 | 05:34 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Have you tried both the hard and soft pull up settings?.
Lower left on the screen.
Old Jul 6, 2003 | 05:36 PM
rooster433's Avatar
Do you mean by selecting COMM1?
Yes i've tried
Old Jul 6, 2003 | 05:45 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Yes i've tried
With the Romulator plugged in there should be an option for hard and soft pullup. What version of the software do you have?
I'm working from memory here, mines out in the garage.
Old Jul 6, 2003 | 05:56 PM
rooster433's Avatar
v1.20
Mine always reads "looking for ROmulator" but it programs fine and all goes well until you plug it into the cars computer.
Tunercat RT does the same. It will snyc with the romulator until you have it pluged into the car
Old Jul 6, 2003 | 06:10 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
v1.20
If it's looking for the Romulator, then something is wrong.
You can load the buffer without the romulator attached, but to load the ROM means being able to see the Romulator, as I understand it.
When it sees the Romulator you then have the option for hard or soft pull up.
On R_T try the other comm settings.
When you try programming the Romulator with R_T do you see a yellow square in the lower L/H corner?.
Old Jul 6, 2003 | 06:12 PM
rooster433's Avatar
yep, and if it is not connected to the car it turns green.
I can load buffer then send to rom fine.. EXCEPT for when the thing is on the car.
I agree, it shouldn't be looking for the romulator for so long.
Tunercat looks and finds it after about 45 seconds. I don't htink the romulator software sees it at all.
I really want to figure this out, tuning a roots blower is pretty difficult and this would make it a bit easier
Old Jul 6, 2003 | 06:25 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Try loading the Romulator thru R_T.
Then plug the Romulator into you prom prgrammer, and try to read it. If you can read it, then compare that .bin to the original .bin you loaded. That will tell you if your for sure loading the Romulator.
If your for sure loading the Romulator, then it's a matter of the pull up being wrong, or the ecm doesn't see the Romulator.
If the Romulator does load correctly, without being attached to the ecm then try loading it, and then plug it into the ecm, and see if the check engine light works.
Mine also takes about 30 secs to find the Romulator when first fired up.
Xtronics is working on a cure for the 7060 pcms, maybe that'll be a cure for your's, too. On my 7060 everything looks right, but no SES light, and the engine doesn't run right.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
