rs232 adapter
Old Jul 8, 2003 | 11:17 AM
mmcdjs's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.1 V6
rs232 adapter
Has anyone tried to use one of these adapters before? Here's the link to them
http://www.al-williams.com/rs1.htm#Order
Old Jul 8, 2003 | 12:20 PM
papaford's Avatar
this is what I use..http://www.quatech.com/catalog/rs232_pcmcia.php
But I never saw what you have.. sure is a lot cheaper than what I did.. however it works great.
Old Jul 8, 2003 | 12:23 PM
mmcdjs's Avatar
Engine: 3.1 V6
rs232
I don't have the budget for that card, but it sure looks nice!
Old Jul 10, 2003 | 07:20 AM
gunther's Avatar
Re: rs232 adapter
This is a RS232 to TTL converter, Is this what you need?
Matt
Old Jul 10, 2003 | 07:45 AM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
I don't think you understand what that piece is?? It is a ALDl interface cable adapter to allow your cars ECM to be connected to your PC to check the data. It is not a PCMCIA for a laptop.
Old Jul 10, 2003 | 10:51 AM
slowTA's Avatar
Car: '88 Formula
Transmission: T-5... in need of slight rebuild
So in other words the pic at the top of this thread will only work if you have a rs-232 port on your laptop already, right?
Old Jul 10, 2003 | 11:50 AM
gunther's Avatar
The adapter at the top is for electronic projects that require interfacing a Microprocessor to a RS232 port. This board is designed for easy prototype of designs that might require RS232. If you plug it in to your laptop RS232 port and supply the 5V and GND then you it will translate RS232 to TTL(5V Levels).
So basically unless you are building a microcontroller project, it won't do you any good.
InfernalVortex
Apr 20, 2021 11:31 AM
Twin_Turbo
Mar 14, 2016 10:10 PM
WejaZ28
Oct 3, 2015 07:38 PM
dusterbd
Sep 29, 2015 08:40 AM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
