Romulator and USB
Old Jul 16, 2003 | 05:48 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Romulator and USB
If your using a Romulator and the Radio Shack USB converter, and try loading a new bin with the ecm on, it might lock up.
Just turn the ecm off.
Unplug the USB connector.
Wait a few seconds.
Then try reloading the .bin file with the ecm off.
Old Jul 17, 2003 | 01:06 AM
CrazyHawaiian's Avatar
Car: too many ...
What version of USB is that? I dont know if it makes a difference, but USB v2.0 is supposed to be alot faster than v1.0.
Old Jul 17, 2003 | 06:02 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
v1.0
Is it just a software change?.
Old Jul 17, 2003 | 07:45 AM
MonteCarSlow's Avatar
Car: 1988 Monte Carlo SS
Engine: 5.7L TPI
It's a hardware specification. V2.0 operates at a faster "baud" rate, probably lots of other new features too that I haven't read about yet.
Old Jul 18, 2003 | 06:46 AM
Car: too many ...
If you want to you can read about it @ www.usb.org. The developers section of usb.org and the FAQ get pretty technical. There is also an overview at Intel's Website with a spec sheet. At first I was thinking maybe the Romulator crashes/freezes because the USB v1.0 connection is too slow (low baud). But after reading about USB I dont think thats the case. Whats the bandwidth (baud) of the ALDL cable that works good? Maybe it might have something to do with how the USB transfers data? Like maybe in bursts instead of constant? I dunno enough about it to really say.
Old Jul 18, 2003 | 09:34 AM
Balael6's Avatar
Car: 1988 Formula
Engine: Twin Turbo .60/.63 305
Transmission: T-5 5 speed
With the romulator, can you use both winaldl and rt tuner at the same time? if so how fast of laptop are you using?
pj
Old Jul 20, 2003 | 11:34 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
I doubt it has anything to do with USB v1.0. USB v1.0 is still much faster then your serial port so there should be no problems speed wise using a USB to serial adapter.
Old Jul 20, 2003 | 03:39 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Dunno about winaldl, but I can run Diacom or Turbolink with the Romulator.
Dell CPx, I'm not sure of the processor's speed.
9192camaro
16
Feb 3, 2019 12:21 AM
Swapmaster
Sep 4, 2003 10:15 PM
BOWTYE8
Aug 23, 2003 06:40 AM
jnjspdshop
Jul 6, 2003 06:13 PM
rooster433
Jul 2, 2003 11:17 AM
