Will my 486 run romulator well enough?
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Cant answer u for sure there on the speed , but do make sure u have 128k memeory or it wont run :-)
Im running on a borrowed pentium2 for right now and my diacom is on a 486/75 or 90
Later
Jeremy
Later
Jeremy
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
I run the TC romulator on my 300MHz and 128 MRam and having some trouble with the graphics. I talked to TC and I will test some stuff later to se if it helps............
/N.
/N.
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
I'd very much doubt it if you plan to run the TunerCat frontend. There's no way it'll run well on my 486-75 /w/ 24MB even, and frankly it won't run for much good on my P-166 either.
While TunerCat is a nice pretty program, it is a resource HOG just like most modern software. So you will probably need at least a P3-450 /w/ 128+MB if you want to run it comfortably.
Car: 87 T/A
I wouldn't go that far. It's not as though TunerCat R/T will be the only game in town forever...
That would be great
Thats why I'm scared to get another laptop cause i'm afraid my moates scanware will not work well with.
and im not ready to give that up ..
I have used others but come right back to your craig.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Originally posted by 87_TA
LOL, OK THANKS.
16k memory here
LOL, OK THANKS.
16k memory here
you probly have 16MB of memory.
you only need 128k free..
1024k = 1MB
depending on how much overhead the OS and whatever else is running takes, you probly do have 128k free
Car: 87 T/A
I think it's mostly the Windows bloatload that drags it down. When I try to do TunerCat stuff (not even R/T) like moving 3D plots around or incrementing sections of a table, it dang near brings it to the knees. Even the P166 I use gets pretty grumpy.
eightsixseven
Dec 16, 2024 01:50 PM
Fast355
Dec 2, 2016 06:33 PM
