ARAP or APYP can't replace AFKN?
Old Sep 14, 2003 | 03:27 PM
88TAJeff's Avatar
Car: 88 T/A
Mods I hope this is in the right forum.
I got 2 chips burned for me by a member. He tried them in his car and apparently worked fine. Simple APYP with inj. const. change, and ARAP with the same change, along with some timing changes for Iron heads. When installed on my chip socket on my memcal, I get spark but no inj pw while cranking and it won't start of course. Put the stock chip in & it runs no prob, so it's not my connections. Will ARAP or APYP not work for me (AFKN)? Car in sig.
Thanks.
Old Sep 14, 2003 | 05:50 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: ARAP or APYP can't replace AFKN?
Thanks.
I'd say no, something to do with VATS.
RBob.
Old Sep 14, 2003 | 06:08 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Thanks.
Don't count on anything other then what you do.
Would you take some pills you saw laying in the street?.
And if you say it's not the same thing, then just remember why you just posted.
Now, the guestion is what else might be wrong with it?.
Old Sep 14, 2003 | 08:27 PM
Morley's Avatar
Make sure he disabled VATS in the chips.
Old Sep 14, 2003 | 09:22 PM
88TAJeff's Avatar
Car: 88 T/A
It cranks and cranks but doesn't start. Doesn't vats disable the starter relay? Just curious...
Old Sep 15, 2003 | 11:00 PM
88TAJeff's Avatar
Car: 88 T/A
Well if his car was say- an '86, then wouldn't vats HAVE to be disabled for it to work in his car?
Hmmmm...
Old Sep 24, 2003 | 11:22 PM
86CamaroZee's Avatar
The VATS chip disables your fuel injectors, if the guy did not turn off the vats switch on the chip that would explain your problem
Old Sep 25, 2003 | 08:06 AM
88TAJeff's Avatar
Car: 88 T/A
Yeah I realize now that the VATS disables the injectors. He sent me 2 more chips without vats.
Old Sep 25, 2003 | 01:31 PM
Did you try them yet how do they work?
Old Sep 25, 2003 | 02:37 PM
scorp508's Avatar
Car: Corvettes
Engine: Modified L98 & LT5
Transmission: DN 4+3 & ZF6
Axle/Gears: 3.07 & 4.10
Thats strange, in the Vettes VATS won't even engage the starter relay.
Out-Cast
Dec 31, 2015 04:40 PM
dyeager535
Aug 28, 2015 08:10 AM
Dan Hubbard
Aug 12, 2015 09:05 PM
marcusaw
Aug 10, 2015 08:13 AM
Fronzizzle
Aug 9, 2015 01:15 PM
