Ford SVO injectors
Old Sep 15, 2003 | 08:37 PM
Ringmaster72's Avatar
Car: 1989 IROC
Ford SVO injectors
I am finally getting ready to burn my own chips and had a question about the ford injectors. Since they are rated at a different ohm, do you still program tunercat for the lb. they are listed or will i need to treat them like they are larger/smaller than the rated lb.?
Tim
Old Sep 15, 2003 | 11:51 PM
Swapmaster's Avatar
If you have the Ford 24# injectors set your constant at 26#.
Old Sep 17, 2003 | 04:23 PM
scorp508's Avatar
Car: Corvettes
Engine: Modified L98 & LT5
Transmission: DN 4+3 & ZF6
Axle/Gears: 3.07 & 4.10
I have Ford SVO 24# injectors, but changed my constant to 24# after I dropped the fuel pressure to 38psi.
Old Sep 18, 2003 | 07:03 AM
JohnL's Avatar
It's not they are "rated at a different ohm" that is relevant, but they are rated at a lower fuel pressure than the injectors in the binary that you're using.
The injector flow difference from one fuel pressure to another is proportional to the square root of ratio of the pressures.
So if you quadrupled your fuel pressure (x4) you'd double the flow through the injectors (x2= SQRT(4)).
John
Old Sep 18, 2003 | 08:37 AM
icecold's Avatar
Car: 1990 formula
Engine: 350 tpi supercharged
Transmission: 700 r4
flow rate at different voltages
anyone know if this is a issue with the ford injecters.and if so where can you get their stats
pete
Old Sep 18, 2003 | 08:48 AM
northern-tpi's Avatar
Hey Ringmaster
Hey Ringmaster72 how is it going with learning how to burn your own chips. I have a 355 tpi with World Sportman II heads, ZZ9 camshaft, Ford 24# injectors, 1-3/4 SLP headers, forged crank, 4 bolt main, and pink connecting rods and trw pistons. I am still running on the stock chip. It is a little chunky, but nothing that makes it undriveable. This winter I plan to get more aquainted with what is involved with burning and programming my own chips. Do you have any suggestions or roadblocks that you have hit??
Old Sep 18, 2003 | 11:51 AM
Br1dgeman's Avatar
Car: Depends on what day it is..
Engine: Um, Chevy small-block
Transmission: One that shifts
Axle/Gears: Got those too...
Scorp508 is right...
SVO injectors are flow rated at 38 psi, GM at 43 psi. They function the same, just need to properly compensate for them in the bin.
Old Sep 18, 2003 | 12:22 PM
Car: 1989 IROC
Northern, i have not actually burned any yet. I was going to this week, but something is wrong with my pocket programmer so i have to send it back, which sux. I think i have a basic idea of what to do, but as far as roadblocks, i think the hardest part is just getting the stuff and convincing urself to finally do it. Luckily you can always come on this site to get help. There is so much info u need to know and i cannot imagine trying it without all of the info on this site. Right now I have a chip with the arap bin and 24 lb injectors that a member here burned for me a while ago. It gets me by, but does not even begin to compensate for my mods. Good luck geting started.
Tim
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Veaceonee
Sep 29, 2016 08:15 PM
92-Formula
Dec 12, 2015 10:34 PM
webeeZ28
Sep 14, 2015 12:00 PM
