Knock counts going crazy
Old Sep 30, 2003 | 12:18 PM
Chris Etemadi's Avatar
Car: 1991 Z28
Engine: 5.3 Gen III SBC
Transmission: 4L80E NTC 258mm Stall
Axle/Gears: Trick Chassis 9" 3.50 S-Strac
I hooked up my scanner last night, and I noticed that at Idle my knock counts were racking up steadily and that It was taking out ~2-5 degrees pretty constantly. I am also getting an Intermittant code 42 and 43, I can tell when the light is about to come on becuase It will be sluggish and a few seconds later it will set the light off. Do you think it could be a faulty knock sensor?
Thanks, Chris
Old Sep 30, 2003 | 12:23 PM
Ronny's Avatar
I get them at start up. it senses the starter engaging/ cranking. I assume this is not your case?
Old Sep 30, 2003 | 08:52 PM
Car: 1991 Z28
it gets them then too
Old Oct 1, 2003 | 10:03 AM
Ronny's Avatar
I have been getting them at 2200 and 40 map, speed density system. this am that was the only area. i assume i remove 4 degrees or so in main spark table and try again? I am running 10 deg initial advance. 206/216 @ .05 cam(non roller) and 64 cc edel rpm alum heads 350 cid. somewhere i was told 10 deg initial advance was Ok and max? I ran 6 deg initially and changed it a month after motor done. Now I question if that is too much advance? since i am getting KC only in that area 2200-2400 rpms at 40-50 map( has happened every other data log) maybe i am ok every where else cept there so removing in that area only OK ???
Old Oct 2, 2003 | 11:36 AM
Car: 1991 Z28
Yea would try removing some there. also you could be going alittle lean, so yo could try adding alittle bit of fuel there
Old Oct 2, 2003 | 12:23 PM
Ronny's Avatar
good point. i will check blm at that point too. funny lean some other spots. varying degrees of lean but no knock counts. i think at that area there is a lot of load on engine and that may induce KC.
Old Oct 2, 2003 | 07:57 PM
kevm14's Avatar
Car: 93 Caprice 9C1
Engine: L05
Transmission: 4L60
I get KCs at startup, but I get a lot more at shut down, oddly. I've seen WinALDL add like 254 counts in high load (95kpa) low rpm areas (400 or 600). I dunno if it's WinALDL or what...I just find it strange.
Old Oct 3, 2003 | 09:46 AM
Ronny's Avatar
i read somewhere that that is normal? something about 400 rpm and 90 map is not a KC but something like a check meaning all OK. maybe system is functioning on KC/retard program. ignore that field??? happens to me too. there is a posting somewhere.
Pac J
May 17, 2020 10:44 AM
RedLeader289
May 28, 2019 01:47 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
Zell1luk
Sep 29, 2015 10:36 AM
