has anyone noticed this?
Old Oct 24, 2003 | 06:53 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
I was looking through my stock bin (88 tbi) and I noticed that there is no speed limiter (set to 255) and the highway mode is activated in the stock bin. I thought maybe someone had edited it before me but others that i came across had this as well. I wish i had known about the lack of the speed limiter, i would have driven faster. Seems that it was a bit unusual to have these settings from the factory since the other bins for other ecms seem to have the speed limiter set and no highway mode (to my knowledge).
Old Oct 24, 2003 | 06:58 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
my 90 had a speed limiter, but did have hi-way mode activated. did you read the actualy stock bin? or download one from somewhere, the way i understand it, all the cars that didn't get the 'performance tire' option were speed limited for liability because of the rated speed on the tires.
Old Oct 24, 2003 | 07:10 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: has anyone noticed this?
Codes vary.
that's why when folks try to make sweeping statments, they're often wrong.
Old Oct 24, 2003 | 07:28 PM
Car: 88 Camaro SC
Engine: SFI'd 350
im not trying to make a sweeping statement. But it did stike me as unusual that there was no speed limiter with the car since its a low-po engine that seems to have come with the run of the mill options. Could eb wrong, though. The bin was right off my stock unmolested factory prom.
Old Oct 24, 2003 | 11:16 PM
JPrevost's Avatar
Car: 91 Red Sled
Interesting, didn't know 88 had the speed limiter disabled. Learned something new today. Could you do me a favor and double check that's correct by setting the fuel cut off to something like 4mph and resume at 10mph, the back out of driveway and make sure car stalls out completely. That'll tell you for sure if stock it came with the limiter at 255.
Old Oct 24, 2003 | 11:54 PM
Car: 88 Camaro SC
Engine: SFI'd 350
I was thinking the same thing... ill try that tommorow.
Old Oct 25, 2003 | 09:37 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
dimented24x7, your '88 uses the '8063 ECM?
RBob.
Old Oct 25, 2003 | 11:39 AM
Car: 88 Camaro SC
Engine: SFI'd 350
JP, i tried that today and it stalled as soon as i exceeded 4 mph. Yes, im using the '8063.
Old Oct 26, 2003 | 11:01 AM
JPrevost's Avatar
Car: 91 Red Sled
Cool, just making sure
Old Oct 26, 2003 | 11:33 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
call me old fashion, but i tested my speed limited the old way...
i floored it until it suddenly stopped pulling. it cuts out at about 114... just like it should.
Old Oct 26, 2003 | 08:10 PM
JPrevost's Avatar
Car: 91 Red Sled
If I did that with the stock ANLU eprom I would have to have enough power to get up to 255mph.... kind of a dumb way to check the speed limiter don't you think.
Old Oct 26, 2003 | 08:44 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
naaaa....... id love to have enough power to get to 255....
hey, if the car cant go fast enough to hit the limiter... there isnt one
Old Oct 26, 2003 | 09:37 PM
JPrevost's Avatar
Car: 91 Red Sled
What if your limiter has been patched to look at rpm instead of vss? Works nicely to keep your out of "darn another valve dropped" and I tend to stay away from this limit if possible. 6000rpm works very well.
Old Oct 26, 2003 | 09:47 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
yea, i read about that mod... pretty sweet idea..
use the same programming but have it look at the RPM variable instead of the VSS.... then it cuts the fuel out at a specifc RPM instead of MPH...
athough i think id set mine to 6700 or so....... but im building a big solid roller motor.... hehehehe.
RedLeader289
May 28, 2019 01:47 PM
86IROC112
Nov 7, 2015 06:50 AM
ULTM8Z
Oct 2, 2015 01:25 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
