7730 computer ground
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
i am chasing a surging/dieng problem. We have tried/replaced everything we can think of. So we go to the computer. Try a chip without the Craig Moates adapter same thing. Then we start checking voltages from/to the ecm and check the b5/6 (I think) on the 24 pin connector. It is the sensor ground for Map/TPS?IAC and temp I think. With the key off it has a 0 ohm reading like it should. As soon as I turn the key on it jumps to 40-45 ohms. Can that be right? All grounds on the motor are good. I will be trying a new computer today. Any suggestions/and does my ground seem OK or not?
Thank YOU
Chris
Thank YOU
Chris
Car: check
Engine: check
Transmission: check
The ohms reading is off as there is a voltage drop in the connection/wire. For circuits under power use a (mill-)volt scale to read the actual voltage drop.
RBob.
RBob.
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Thanks... I did that and replaced the computer. Still no dice. Do you think my program could be off in the chip to cause a bad idle surge/stall? What are the main tables I should look at?
Chris
Chris
Car: check
Engine: check
Transmission: check
Chris
Chris
If you have removed MAF screens or did any gutting then the MAF scalar tables are off. Even if you didn't they probably need to be tweaked anyway.
Lots of info on dealing with MAF scalar tables in the archives, search & ask questions.
May also need to add more SA timing at idle. Lots of overlap on that cam. Increase idle RPM too.
RBob.
gta892000
Sep 16, 2015 12:37 AM
Glowsock
Sep 5, 2015 07:48 PM
