Craig's software not linking on new Laptop.
Old Jan 30, 2004 | 02:38 PM
87_TA's Avatar
Well just as I was scared of, Finally received my newely used Laptop, Immediately installed ECM852, and it wil not connect with ECM?
Anybody know why not?
Is 851 and 852 any different? My old machine was using 851 with out flaw.
Old Jan 30, 2004 | 02:57 PM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
Make sure Moates' software is configured to the correct com port. You can check what com you laptop is running in the windows device manager.
Old Jan 30, 2004 | 04:02 PM
87_TA's Avatar
Thanks! But....
What Com port should it be configured on?
Sorry Im still a little pc illiterate.
EDIT:
Nevermind
That was it!
It was disabled in device manager - I didn't even know you could do such a thing. LOL
Well thanks again Plant,
Very appreciated..
Old Jan 30, 2004 | 04:15 PM
Haha, didn't have your edit up before I hit reply. Glad I can help.
Old Jan 30, 2004 | 09:09 PM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
I've never been able to have it connect in windows 98, I always have to boot the laptop in dos.
Old Jan 30, 2004 | 09:18 PM
jeepguy553's Avatar
Car: 1980 Jeep CJ7
Engine: AMC 360 with GM TBI
Transmission: TF727 set for kill...let's get it on!!!
Check your COM port settings in Windows. Look at the Device Manager to see what port (COM1, 2, etc) your serial port is on. Generally, you will have 2 COM ports on a Win98 machine...sometimes more depending on hardware configuration. IIRC, the COM setting for a serail port will probably be COM1. You will also have a parallel port and if you have a printer, it will be named LPT1.
Old Jan 30, 2004 | 09:27 PM
The parrallel port works because my Pocket Programmer works.
Com Port 1 is my communications port, and it also lists the LPT1 port. (COM1 is NOT disabled.)
In ECM852, com port number is set at 1.
But I still can't get data with windows operating.
Old Jan 30, 2004 | 09:37 PM
jeepguy553's Avatar
Car: 1980 Jeep CJ7
Check the COM port settings like port speed, stop bits, parity, and flow control. Set FLOW CONTROL to "NONE" since that parameter is simply a "your side" control in a manner of speaking.
Old Jan 30, 2004 | 09:42 PM
BPS: 9600
Data Bits: 8
Parity: None
Stop Bits: 1
Flow Control: None
That's what it has.
Old Jan 30, 2004 | 09:55 PM
jeepguy553's Avatar
Car: 1980 Jeep CJ7
Try changing the bps to a lower setting and work from there. I am not sure about your particular software setup, but starting from a lower speed and going up from there seemed to help me in the past.
HTH...
Old Jan 30, 2004 | 11:11 PM
Z69's Avatar
Z69
If you have a mouse in your serial port instead of the PS/2 or usb, it can cause conflicts. The old ones usually use a serial plug. You can get an adapter for a PS/2 port. If something is set to com 3, it will actually use com 1. Some modems will do this. Old ones again.
Old Jan 30, 2004 | 11:16 PM
jeepguy553's Avatar
Car: 1980 Jeep CJ7
All very good points. I have to get the mouse off of my Dell everytime I want to use the POS PackardBell desktop I have in the garage. The mouse it has is a SERIAL port (9-pin DB9) mouse and I need that conxn for the AutoProm I/O.
Please...someone get me a decent laptop...or some EDO memory for my Toshiba!!!!
Old Jan 30, 2004 | 11:43 PM
Waltj's Avatar
Car: 86 Monte Carlo
Engine: 86 305 TPI w Vortech Blower
What model Toshiba? I have 64 megs around here some place. It's for a 510 Tecra. Let me know if it will fit.
Old Jan 30, 2004 | 11:50 PM
jeepguy553's Avatar
Car: 1980 Jeep CJ7
Toshiba T2100 Satellite. EDO RAM. I have no idea if it will fit...really. I'll check , though. If it will fit, I'll PM you.
Thanks!!!
Old Jan 31, 2004 | 02:20 AM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
what you should really do is boot to dos and use ECM852 in dos mode. don't let windows interfere with the program's control of the com port.
Fanatic1074
Oct 3, 2022 05:57 AM
3rd gen money
Oct 11, 2019 09:57 PM
Ed1LE
Sep 30, 2018 09:14 AM
loud91rs
Oct 5, 2015 10:05 PM
SavingPvtEric
Sep 29, 2015 05:59 PM
