Stock BLMs vs Altitude
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Hey folks.. was just browsing through the 88 TBI FED AUTO base prom, and noticed there was a setting for "minimum BLM" which is at 108.. some of my BLMs *are* 108.. so.. I'm greatly concerned that perhaps I'm losing fuel milage based on running rich. Is it possible for BLMs to run this low on a stock chip at ~5000 feet? Does this warrant dropping my BPW a few msec? Any speed density folks, peferrably TBI, living near 5000 feet know their BLMs on a stock chip? Thanks in advance.
The blm is used to correct the afr in closed loop to 14.7. The ecm is adding fuel to try and get to 14.7. You may have an air leak in the exh or a faulty o2 sensor or some other problem. At least that's how it works in a 7730.
Car: check
Engine: check
Transmission: check
It may be a calibration issue. The '88 MY used a one year only '8063 ECM and was the first year for the LO3. GM may not have gotten it dialed in just right. There is a barometric compensation routine in the code and that may also be off.
The other possibility is that the CCP system is picking up a lot of vapors. This would contribute to the rich AFR the O2/ECM is seeing.
RBob.
RBob.
Car: An Ol Buick
Engine: Vsick
Re: Stock BLMs vs Altitude
Engine: LS1, Scrap
Exhaust leak, no. EECS, deleted. O2, possibly, but I don't think it would be both showing rich and actually being rich... I think the calibration issue may be something.. I'll go ahead and pop open a 89-92 chip.. see what GM did with the baro routine and such...
Engine: LS1, Scrap
I think your solution is a bit extreme in my case, Grumpy.. no wbo2, and I regularly drive between 3k and 6k feet.. so I still need dynamic range... BLMs are my friend.. I just have to drag myself within their limits..
Car: check
Engine: check
Transmission: check
. . . I regularly drive between 3k and 6k feet.. so I still need dynamic range...
RBob.
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Car: An Ol Buick
Engine: Vsick
Upping the BPC, does that. And allows for a greater amount of change per BL change.
Engine: LS1, Scrap
ooooohhhhh.. and all I'd have to do is divide the VE tables by whatever i'm multiplying the base pulse width by for a base tune?
Car: An Ol Buick
Engine: Vsick
That'll get you close to start with.
Genopsyde
Oct 7, 2015 08:35 PM
