Forcing open loop on the 8746
Old Mar 1, 2004 | 01:15 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Hi,
I am trying to pass the good old Oregon State Sniffer
i treid to force open loop, since i was failing HC's really badly at idle, i figure this is due to the cam, and the false readings of the o2. when i set the closed loop enable temp to 255, it still seemed to correct for lean BL's. i then set the blm enable constants to points that i would never reach, it still seemed like it was correcting (o2 values around .450, HC readings never dropped, no matter what i did the tables). the only way i could get the o2 readings to drop, and the HC's on the test to drop, was to set the closed loop timer to 500seconds, this worked, but i have to get throught the test in those 500 seconds. is there something i am missing in disableing BL corrections, and forcing the computer to run purely off the tables at all times?
Old Mar 1, 2004 | 01:41 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Forcing open loop on the 8746
Originally posted by Dewey316
Hi,
Need to set the closed loop coolant enable threshold to 0. The coolant term in the '8746 is inverse.
RBob.
Old Mar 1, 2004 | 01:45 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Thanks Rbob, that would surely due it.
Old Mar 1, 2004 | 01:46 PM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
I was helpin him try to get through the sniffer, and were were looking for O2 Swing points in the code.
Couldn't find any. Any ideas? Or just keep her in open loop and take out fuel?
Weird thing was, we'd take out fuel run it through, ALMOST pass, take out a smidge more fuel and be back way high on HC again?
What the hell?
Old Mar 1, 2004 | 01:49 PM
Ronny's Avatar
is 500 secs the max timeout on going CL? coolant temp and time i think are the 2 constants that can be set for closed loop switchover from open. i run a 7747 with tunercat. if you lock open i assume it runs off existing VE tables and the PE adder. how then is PE initiated? i am aware of AE being a function of TPS movement as well as MAP but uncertain whether PE is similar or dependent on RPM's over 3600 to trigger it. i too am considering running open loop only at idle and off idle, when the cam goes in with WB tuning.
Old Mar 1, 2004 | 02:08 PM
Dewey316's Avatar
Car: 1990 Camaro RS
PE mode comes in a certain % throttle, there may be other things needed for it also though.
the real key to the cam would be some sort of rpm vs o2 swing point, then we could lean out the idle and low RPMs.
Old Mar 1, 2004 | 02:32 PM
Ronny's Avatar
so apparently it is all open loop operation 100% of time or delay CLto a max of 500 secs? no other options?
Old Mar 1, 2004 | 02:35 PM
Dewey316's Avatar
Car: 1990 Camaro RS
i will have to look into more, and hopefuly the experts will speak up
Old Mar 1, 2004 | 04:12 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Code:
; in idle parameters
LD24C:	FCB	132	; idle mean R/L O2 threshold
LD24D:	FCB	159	; idle rich O2 threshold
LD24E:	FCB	160	; idle lean O2 threshold
-and-
Code:
;* Mean Rich/Lean Threshold For Unfiltered O2
;* As A Function Of Flow
;* mV = val * 4.34
;* Tbl = 230.4 * Vdc
;* (stored in L004E)
LD3CF:
; 	mvdc 		; air flow
	FCB 120		;  0
	FCB 120		; 16
	FCB 134		; 32
	FCB 134		; 48
	FCB 130		; 64
;* Rich O2 Threshold as Funct Of Air Flow
;* mV = val * 4.34
;* (stored in L004F)
LD3D4:
; 	mvdc 		; air flow
	FCB 135		;  0
	FCB 135		; 16
	FCB 138		; 32
	FCB 138		; 48
	FCB 132		; 64
;* Lean O2 Threshold as Funct Of Air Flow
;* mV = val * 4.34
;* (stored in L0050)
LD3D9:
; 	mvdc 		; air flow
	FCB 120		;  0
	FCB 120		; 16
	FCB 132		; 32
	FCB 128		; 48
	FCB 128		; 64
8746 hac can be found on Craig's site.
RBob.
Old Mar 1, 2004 | 04:53 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Rbob, the first set makes complete sense.
can you explain a little more on the last three tables.
Old Mar 1, 2004 | 04:59 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
You crossed into having a lean miss.
Old Mar 1, 2004 | 06:26 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The last three are used in the same manner as the idle terms. Only difference is that the table value is based on the airflow through the engine. The higher the load, or the higher the RPM, the greater the airflow.
If all else is OK, cat, O2 sensor, plugs, wires, cap, fresh oil, timing, EGR valve (not leaking); 2 gals of denatured alcohol to 8 gals of gasoline . . .
RBob.
Old Mar 2, 2004 | 07:25 AM
Dewey316's Avatar
Car: 1990 Camaro RS
how exactly is the airflowed figured? it has the addresses for where it gets that information, but is there a way that i can determine what airflow values i have based on my VE tables? something like VE * RPM * 230.4 ?
Old Mar 2, 2004 | 09:39 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Easiest would be to put the gms/sec term out the ALDL, it is location $BA.
The math is:
L002B = ((MapAdc * 189) / 256) + 21
gms/sec = ( (((L002B * 120) / 256) + 18) * (rpm / 12.5) ) / 256
With the final gms/sec value limited to 64. The rpm term in the equation is the actual rpm divided by 25.
RBob.
Old Mar 3, 2004 | 12:12 AM
jeepguy553's Avatar
Car: 1980 Jeep CJ7
Engine: AMC 360 with GM TBI
Transmission: TF727 set for kill...let's get it on!!!
The light bulb came on again. I think I know now why my engine used to have a faint little pop at cruising speeds when I had the ProJection.
Old Mar 3, 2004 | 06:56 AM
Dewey316's Avatar
Car: 1990 Camaro RS
that really doesn't suprise me, we took out SO much fuel. i went ahead and put in a new set of plugs last night, even though the ones in there looked OK, and replaced the o2, even though it seemed to be reading OK.
friday is my day off, so i will be back at the smog station with the laptop...
Pac J
May 17, 2020 10:44 AM
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
luvofjah
Sep 26, 2015 08:28 PM
Nick McCardle
Sep 10, 2015 08:36 PM
