8746 question
Old May 9, 2004 | 08:38 PM
fire1976's Avatar
8746 question
Hi,
I would like to know if someone would have a idea why my TBI runs good with the 747, but when trying a 8746 ecm, it just won't start. I wired the MAT sensor so it's even there when using the 747. I think the signal to the pins are just about the same between both ecm.
Is there any 5L manual 8746 bins that would exist, just was not able to find any. Is there a website that existso I can check all BCC for different ECM.
Old May 9, 2004 | 09:32 PM
steve8586iroc's Avatar
Check over on the DIY-ECM board, I'm sure you will gets some answers there.
Steve
Old May 10, 2004 | 01:54 PM
88305tbi's Avatar
Car: 88sc
Engine: 305 for now
Axle/Gears: peg
perhaps you need to disable the VATS... i'm pretty sure some 8746's have the anti-theft flag, and that would make it not start, if i understand all this stuff... :lala:
Old May 10, 2004 | 07:09 PM
fire1976's Avatar
thanks, that was my problem, wow, the ecu file I had didn't mention anything about VATS.
MAth
Old May 12, 2004 | 12:18 PM
JPrevost's Avatar
Car: 91 Red Sled
MAth
What ecu do you have? If it's the one I put together then where did you get it? There is a bad copy floating around that has incorrect VE table representation. It does however have VATS commented in the options flags. Just open the "comments" and then open the different options and there is a description of which is VATS.
If you don't have my ecu then I can't help.
Old May 19, 2004 | 07:08 PM
fire1976's Avatar
yeah, I do have your ecu. Might have the wrong one. Trying another one at the moment. trying to find some 8746 manual bin also, seem like they're all manual almost. Anyway. Thanks, will check out the one I just found
Old May 31, 2004 | 10:49 AM
Z28GEN3's Avatar
Engine: 305TBI
Axle/Gears: B&W 9 Bolt 3.73
I have your ecu file that i downloaded from mangus's website, im looking at the VATS table, i have VATS freq location 291 and the VATS freq(2) is 293- just want to make sure that its disabled
Old May 31, 2004 | 11:09 PM
jeepguy553's Avatar
Car: 1980 Jeep CJ7
Engine: AMC 360 with GM TBI
Transmission: TF727 set for kill...let's get it on!!!
JPrevost, I went in and made the corrections to the $61 ECU that you recommended, but it made my engine run like crap. Is it possible that I actually got a good copy of the ECU to begin with? I got a great tune going on this engine. I don't want to have to do it all again. Maybe you could run through the ECU corrections again for good measure. Please????
Old May 31, 2004 | 11:11 PM
jeepguy553's Avatar
Car: 1980 Jeep CJ7
In the 8746 stuff, all you have to do is uncheck a flag that enables/disables VATS. I still haven't fooled with the VATS freq and probably won't unless I decide to get a VATS module and a VATS lock cylinder.
Old May 31, 2004 | 11:41 PM
JPrevost's Avatar
Car: 91 Red Sled
Maybe it was right. Send me your latest bin and I'll check it with both versions to see where you need to go from here. I'll send you the latest ecu file if you need it.
, Jon
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
