TPI swap prom choice
Old May 17, 2004 | 11:21 AM
whitess's Avatar
Car: 85 SS
Engine: 305 L69
Transmission: 2004R
Axle/Gears: 7.625, 3.73
What effect does rear end gearing have with the chip? I want to put TPI on a car that has an automatic w/3.73 rear gears but the best stock chip I find is one for an auto w/3.27 gears. Obviously there must be something different (timing, fuel, firing of the injectors) because there are different ones for different ratios, so I would assume that there would be a performance loss, maybe even emmisions, using a chip for higher gears (3.27 or 3.08 or..). The TPI is an '88 setup with MAF and the stock analog speedometer. Since the rear gears are spinning faster the parameters I would think would be different. Any ideas, custom chip maybe?
Thanks, Larry.
Old May 17, 2004 | 01:51 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: TPI swap prom choice
The only way to get the correct will be with you learning how to do your own.
The gearing has alot to do with how you decay out the timing, and the Accleration Enrichment functions. And those areas are typically not even touched by the aftermarket chip guys.
Old May 17, 2004 | 05:38 PM
whitess's Avatar
Car: 85 SS
Engine: 305 L69
Transmission: 2004R
Grumpy,
Thanks, that's kind of what I was figuring.
I looked through the proms for the SD systems and they don't list any gear ratios, just auto or manual transmissions. Is the rear gear ratio not a factor in the SD system PROM's?
Old May 18, 2004 | 11:43 AM
MonteCarSlow's Avatar
Car: 1988 Monte Carlo SS
Engine: 5.7L TPI
whitess: for what it's worth, if you are putting the MAF based TPI on a stock L69, I think you will find the stock 305 TPI calibration to be close enough, if close enough is good enough for you. Been there done that.
The base calibration for SD 305 is so-so in the Monte, I found the MAF base calibration to be better purely from a bolt-it-on and drive it experience.
Auto and Manual SD 305 bins have the same VE table, even though the cam shafts are different grinds. (Food for thought) To the best of my knowledge, the L69 cam is the same as the 1985 TPI 305 cam... so if your L69 is stock now, and all you are doing is bolting on TPI, it's close enough to stock for the stock cal to be reasonable forgiving.
HTH's.
Old May 18, 2004 | 02:12 PM
whitess's Avatar
Car: 85 SS
Engine: 305 L69
Transmission: 2004R
Thanks for the information, every little bit helps.
Larry.
Old May 18, 2004 | 02:51 PM
Engine: 5.7L TPI
Here's what it looks like when you are done your swap.
I hope I didn't spoil it for you.
Good luck!
Old May 18, 2004 | 03:07 PM
whitess's Avatar
Car: 85 SS
Engine: 305 L69
Transmission: 2004R
Oh sure make me want it more!
Looks great. And white too! I'll save the pics for inspiration.
I'm getting anxious to do the swap, right after I get some more "suspension goodies" from Marcus.
Thanks,
Larry.
Old May 27, 2004 | 01:34 AM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
MonteCarSlow, it took me a few minutes to figure out why your a/c compressor is on the left side & mine is on the right side, you stayed with v-belts, i went with the serp belt. where did you get your air box from & what is it off of?
mine doesn't look no where near as clean as yours does, nice job
Old May 27, 2004 | 10:02 AM
Engine: 5.7L TPI
The intake plumbing is from a MAF Firebird, the aircleaner assembly is from a FWD V6 car. I don't remember what the car was (scrap yard item). I installed the aircleaner assembly upside down, and made some other modifications to it. You can't really see it in those pictures, but if you want I can take pics of it to show you.
Thanks. Got pictures of your Monte's TPI?
Sometimes at cruise nights I get the odd person who thinks my TPI install is factory "Yup, special collectors edition... rare..." wink wink, nudge nudge. I even put the "tuned port injection" badge on the trunk lid like they did on Camaro's. TPI Camaro owners notice it....
Old May 27, 2004 | 11:28 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
SAME O'
I do like how you did the intake, turned out nice.
I'm still running the v-belts and air as well but with belt driven clutch fan.
I need to go to the electric because I can't put anything but the K&N right on the throttle body. Its real tight there and with everything on the front there's not even room for an elbow (or anywhere to run to if I could cget the el on there)
I still hate the A/C lines running across and want to do something about them on mine.
As far as the chip goes, I'm using the AUJP on a 350 in mine and its working out good. I'm able to burn changes with the AutoProm and I'm happy with the money it cost to get the flexibility of doing the changes myself.
JP
Old May 27, 2004 | 11:32 AM
JP86SS's Avatar
INFO
WhiteSS,
Grab the schematic from this post:
https://www.thirdgen.org/techbb2/sho...hreadid=242358
I don't know how long I can leave it on the site and it has alot of info for you on the swap.
JP
Old May 27, 2004 | 03:54 PM
whitess's Avatar
Car: 85 SS
Engine: 305 L69
Transmission: 2004R
JP,
Thanks.
Larry.
Old May 28, 2004 | 12:17 PM
JP86SS's Avatar
Just an idea
This give you a good idea of what this took for me to do.
You'll have some better info to start with so good luck!
Old May 28, 2004 | 12:19 PM
JP86SS's Avatar
And ...
This was taken out as well.
JP86SS's Avatar
To get to here
(picture shows almost done.
Old May 28, 2004 | 04:12 PM
whitess's Avatar
Car: 85 SS
Engine: 305 L69
Transmission: 2004R
That first picture looks like you needed a comb.
I'm gonna cheat and get a harness from Howell. (I know, I'm a wus )
Steven 86IROC-Z
May 24, 2026 04:52 AM
gta90
Sep 15, 2015 04:00 PM
camaro71633
Sep 1, 2015 10:24 AM
Sanjay
Aug 12, 2015 03:41 PM
djmarch
Aug 11, 2015 10:22 AM
