Open Loop
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
Open Loop
Well, I thought I had total control of the tune and was in open loop all of the time.
Not so.
I understand that BLM's and INT's are set to 128.
What else do I do to eliminate closed loop for now, while I get it tuned?
Not so.
Car: check
Engine: check
Transmission: check
Re: Open Loop
Not so.
Not so.
RBob.
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
Re: Re: Open Loop
Originally posted by RBob
Set the closed loop enable temperature to the highest possible value and reset the ECM. The reset may or may not be required as some ECMs reset the BLMs to 128 at key on while others do not.
RBob.
RBob.
So, is this the only step necessary, or is setting the BLM's and INT's at 128 also required?
Also, is setting the target idle higher a good idea? I mean, it could allow more vac at idle, especially with a rougher idling cam. Guess it would not be if it causes the TPS voltage to go above 1 volt.
What's hilarious is the factory tune had the WOT delay time at 30 seconds. Guess its because its a truck
Car: check
Engine: check
Transmission: check
Re: Re: Re: Open Loop
Thanks!
Thanks!
Setting the desired idle RPM higher will not affect the TPS setting. Only the IAC counts will increase.
Common for the truck ECMs to have delay parameters for PE mode. Some will even decay out PE SA after a set amount of time.
RBob.
Car: 1990 Chevy 454SS
Engine: 454
Transmission: TH400
Re: Re: Re: Re: Open Loop
Jeezz... I saw the PE delay, but never really thought about it before. Mine is still set to 5 seconds. Thats not what I need for 1/8th mile blasts....
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
Re: Re: Re: Re: Re: Open Loop
The truck ecm's do incorporate a WOT delay but also use a second table for fast entry into WOT which has no delay. This table typically uses a higher TPS setting. There is also an "RPM to bypass WOT delay" constant.
Pac J
May 17, 2020 10:44 AM
FueledSoul
Sep 29, 2015 08:58 PM
