Anyone having knock problems with Super AUJP?
Old Aug 5, 2004 | 08:59 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
I am running a 730 with the Super AUJP code. I have a ZZ4 and I am getting a ton of knock counts has anyone else experience this? I am going to pull timing out but didn’t think the super AUJP had too much timing.
Also here is a really stupid question but what do knocks sounds like. At WOT I hear like a clicking coming from the engine bay / trans area, almost sounds like a exhaust rattle. Just wondering if anyone could explain what a knock sounds like.
Old Aug 6, 2004 | 02:36 AM
Z69's Avatar
Z69
What's your static timing set to?
Might try changing it to see if the noise goes away.
Might be slightly faster than a chip burn....
The knock sound can vary.
Also depends on how hard it is.
I notice my hyperuetectic's sound a little different than forged pistons do too. Or could just be the acoustics of a newer design head and stroke crank combo.
Best I can do is it sounds like a spray paint can being shaken but has a higher pitch usually.
Old Aug 6, 2004 | 02:43 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Any rattling sounds from the engine can be picked up by the knock sensor. Exhaust leaks from header collecotrs seem to be a real popular one as well. Specially us folks with SLP headers lol
Misadjusted valve train or springs suffering from coil bind can trigger it as well, as could bad accesories or belt tensioner.
I dont like the Super AUJP, IMHO it has wayyyyyyyyyyyy too much part throttle timing and the wot is more than I run...(yes i know u ahve aluminum l98 heads)
Have a stock GTA(inj and catback only) using a anjf as a base .bin putting 225hp and 315 ft lbs at the wheels on a dyno and 14.40's at 97mph with 2.3 60's at the track :-)
I use a lot less cruise timing(usally 2 deg less than aujp or anjf) and around 27-28 deg tops at wot. (may even be as low as 26.x have to verify on bin)
Less timing and = to or greater than performance works for me :-)
later
Jeremy
Old Aug 6, 2004 | 12:02 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
I've been running the S_AUJP and have not had any issues with the timing or knock counts.
I get good midrange and real nice drivability from just tweaking the VE tables.
There must be something causing the false readings.
My motor is pretty stock (i think its an 86-88 T/A motor, will find out this winter).
Don't have anything else to add.
JP
Old Aug 11, 2004 | 06:15 PM
clippjr8's Avatar
I just fixed a problem like this last week. The distributor set a 6* would cause a ton of knock using the S-AUJP bin and i could not fix it by just lowering the spark tables so we had to back the distributor down to 2* base timing and all the knock is gone along with the sound of the valves when there is too much advance.
Old Aug 11, 2004 | 11:12 PM
nape's Avatar
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
I blew out a couple rings running Super AUJP and that was even after cutting out a bunch of timing, I was on 87 octane though. I'm sure that had something to do with it, it ran a lot better with 93.
Old Aug 12, 2004 | 04:09 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Well I ran a new engine about 500 miles on the super AUJP until I got around to scanning it and it would go to 255 knock counts then reset a few times over the coarse of a 15 minute drive. I just hope it didn't do any damage!
I just copied the stock corvette tables over and the problem is fixed.
Old Aug 12, 2004 | 04:54 PM
JP86SS's Avatar
I'm only running 93 octane with about 4* BTDC and haven't had any issues. At 6* I did get some constant knocks but just 2* removed it completly. Only get an occasional 4-6 counts when tromping on it.
I'm beginning to wonder why if alot of others are saying there is too much timing.
My knock circuit is working well, etc.
Old Aug 12, 2004 | 06:12 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Is there any way to tell if you blow a set of rings other then to do a leak down test? I did a leak down test and the numbers were pretty bad. Can you measure the blow by via the PCV port or something?
Old Aug 12, 2004 | 08:22 PM
Black 91 Z28's Avatar
Car: 1991 Camaro Z28
I'm running it and am not have in a lot of knocks. I get a couple on cranking and shutting down and 1 or 2 during WOT driving. Other than that it runs fine in closed loop mode. When I start it up in the morning after leaving it off for a while it kinda chugs some..but once it goes to closed loop it's fine.
Old Aug 13, 2004 | 06:45 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
A borescope. The prices have come way down, for under $200 you can get a 1/2 decent one. There's been a bunch on eBay lately.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
89fast5oh
Sep 27, 2015 09:04 PM
db057
Sep 4, 2015 07:57 AM
db057
Aug 22, 2015 08:17 PM
