Car Will Not Connect ALDL
Old Sep 17, 2004 | 04:53 PM
Needin' Tires's Avatar
Car: '98 Z28 M6 & '89 IROC-Z 350tpi
OK, here is the problem. I have been trying for the last few weeks to get my car to connect to my laptop. I am using WinXP Pro with SP2. I am also using a Radio Shack USB -> Serial Adapter. I am using a ALDL Cable from MaStach.com . I beleive everything is working because the ALDL Cable test software says it's ok. So everything from Software/Hardware side is ok I believe.
I have further tested my thoughts when I started up FreeScan. I have the correct COM port selected, set to 9600 with no Flow Control. I have tried with Hardware as well, no change.
When I try to connect I get nothing, I get the x80 x1 x29 x56 or something like that, Unrecognizable Header. Almost like it's just echoing what is being sent.
I have pulled out the ALDL cable from the port and just grounded the data cable to the ground cable. In the status window, I saw bytes coming in, like I was creating them by quickly making a binary data stream. Usually it was like ff or 00 but sometimes it would produce an 80 and there would be a message saying found start header.
I have a 1989 Iroc-Z MAF TPI 350 Car. I beleive it's a 165 ECU. On the chip it says AUJL. There is an orange wire going into the back of the ALDL Connector at pins E and M. I am connecting the Ground to pin A. I am connecting my Data wire to pin M. I also have a 10K Ohm resistor between pin A and B. I don't believe anything else is wrong. Please, I need help.
Thank you
Robert
Old Sep 17, 2004 | 05:38 PM
TC602's Avatar
Car: 86 IROC
Engine: ZZ4
Transmission: T5 WC
I also had problems with Freescan. I gave up on it and went with Craig Moates software. Freescan looks cool but difficult to get connected. Try Craigs software found here http://www.moates.net/index2.html . It is called ECM852.zip
Old Sep 17, 2004 | 05:50 PM
I even tried Craig's software with similar results. I have also tried TTS software ( I know it's BETA ) and even PCMCOMM. I even tried TunerPRO RT's ALDL scan tool. Nothing works. Please HELP! This is bugging me like no other.
Old Sep 18, 2004 | 08:01 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Try disabling any kind of network, IR or PCMCIA card slot services that may be running at the same time.
I don't have XP so I don't know what basic items to tell you.
Something must be interacting. Maybe the USB->serial converter ?
Keep looking, Magnus has proven TP to work on the 165.
Old Sep 18, 2004 | 12:21 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
Sounds like your USB-serial to converter.
Old Sep 19, 2004 | 11:33 AM
SBNova's Avatar
I have a compaq presario 900, running windows XP, and Im using the 'shack USB-serial adapter. I have WinALDL running fine on my 85 Vette- which is now using a 165 ECM- the same as yours. I can tell you it took a while to get mine sorted out. One major prob I had was that I was using a cable (built myself from the WinALDL schematic) that required an external power source. I put a cigarette light lug on it and plugged it in. Should be good right? Nope, Corrosion on the socket kept it from working.
Old Sep 20, 2004 | 10:07 PM
Ok guys, thanks. I just ordered the Belkin adapter. Hopefully this will solve the problem.
Robert
Old Sep 23, 2004 | 06:26 PM
Alright, recieved the Belkin Adaptor today, and guess what? Nothing. Notta, nil. The ALDL Test program won't even pass it. This is getting Frustrating. I guess I'm gonna have to buy Craigs USB Autoprom. Oh well. Can anyone else guess why this isn't working?
Robert
Old Sep 23, 2004 | 06:29 PM
Mangus's Avatar
Transmission: T5WC
its very likely that the adapter (driver) doesn't like to be opened at the required 8192 baud directly. 8192, in baud land, is a strange number. Craig does offer a direct USB->ALDL interface, such that you wouldn't have to use an adapter. =)
However, buy the AutoProm and you get a TunerPro reg included! hint, hint, nudge, nudge. ;-)
Old Apr 9, 2005 | 09:14 PM
dakleenupman's Avatar
Car: 2000 Astro
Engine: 4.3L of funk
Well, did anything positive happen in this situation?
BRoss99
Aug 10, 2025 05:08 PM
TheExaminer
Aug 26, 2015 04:59 PM
apie2546
Aug 10, 2015 05:43 PM
Bull86
