Bin stacking issues
Old Sep 20, 2004 | 12:06 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Bin stacking issues
Okay I have a bin switcher for 256 chips. Basically, it appears to connect pins 27 and 28 for the "LO" program and pins 14 and 27 for the "HI" program. It also doesn't allow pin 27 to connect to the MEMCAL (which makes sense since this bit gets switched).
On the sheet of paper that came in the mail with the "BinTrader", it says for 16k sized bins, the addresses are "0000-3FFF" and "4000-7FFF" which makes perfect sense so far.
Now, I can make the 32k bin file with two 16k bins just fine. I've used BINCompiler as well as TunerPro to stack the bins, and they appear to stack perfectly. With the AT29C256 in the burner by itself, it appears to burn my exact (stacked) bin file to the chip, and I verify this by re-reading the chip after burned. Perfect, everything is at it should be.
Now, when I stick the chip in my BinTrader, it fails to work in my car (the fans come on, etc.), no matter what position the switch is in. The interesting part is that if I set my burner back to read 27128 chips and put the EEPROM back in the burner (with the BinTrader attached), and flip teh switch to any of the positions, I don't get a valid bin back. I get a 16k read, but no values match up. I figure when doing this, the values should match up with a single 16k BIN file because its how the ECM would be reading the chip through the BinTrader.
Is there any reason this would be happening? Like I said, if I read the chip as an AT29C256, I can see where my first bin ends and the second starts (3FFF/4000) and it appears to have burned perfect. When I stick it in the BinTrader and try to read each 16k portion separately, they don't read as the separate 16k BINs I stacked.
Is there any reason for this? I'm using a Willem PCB3 burner, a BinTrader (for 2x16k on 256), and AT29C256 chips from Craig.
EDIT: Read up a little bit on the 29C256 datasheet, and the design of the switcher *should* be perfectly okay since pin 27 is A14, and the switch just flips it between VCC (pin 28) and ground (pin 14).
Old Sep 20, 2004 | 05:51 PM
Car: 1997 Corvette
Anyone? I can't even get it to work if I burn a single bin with an offset of 4000. 0000-3FFF are loaded with 00, I thought I read that should be "FF", but TunerPro fills it with 00s.
Old Sep 20, 2004 | 06:20 PM
Car: 1997 Corvette
*sigh* I think I just figured it out
Old Sep 20, 2004 | 07:07 PM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
well how did ya Fix it. Don't leave us in suspense.
Old Sep 20, 2004 | 07:47 PM
Car: 1997 Corvette
Well, it ended up the whole blanking 0000-3FFF with "00"s was no good, so I loaded it with "FF"s from 0000-3FFF, and it worked once. Then I brought it back inside to see if I could get the switch to work, and I couldn't. I'm assuming its something with the checksums maybe?
Now I re-burned the chip same as I did before with "FF"s for the first half and it wouldn't run (would turn the fan on etc.). So I just took the ECM casing off and checked for continuity between my newly soldered-on switch to the MEMCAL and all is good. Must be something in how I'm burning it again. I'm going to keep working on it, but I'm moving kinda slow tonight with how sick I got today :/
Old Sep 20, 2004 | 08:00 PM
Car: 1997 Corvette
Now I really don't know what's going on. It just turns the fan on still and this chip is burned identical to before I think.
If someone could send me a stacked BIN that they use and knows to be working, please send it to me. Even if it isn't a good tune for my motor, all I want to do is be able to turn the key without the fan turning on.. my email is dean@xibase.com
Old Sep 20, 2004 | 08:04 PM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
where did ya get the BinTrader I seen craigs bin switcher But I havent heard of the Bin Trader
Old Sep 20, 2004 | 08:24 PM
Car: 1997 Corvette
*sigh* eBay. The guy used to frequent these boards a while back I guess he said.
Anyways, all the pins check out, and the switch seems to work just fine. Its just a matter of getting a chip to work :-/
Old Sep 20, 2004 | 09:11 PM
Car: 1997 Corvette
Well, its not the checksum because I put "AA" into the one cell which equated to 170 in the other...both of which I've heard to ensure you bypass the checksum...
I don't get this one bit. I mean, I've checked the pinout of the AT29C256 and compared it to the design of this circuit, and it matches up perfectly with what I'd expect and with what Craig's info on his site is about getting two 16k programs on on 256.
I checked and double checked all of my solder connections and all have 0 ohms resistance, and none are touching each other. I've tried a few different BINs now and filling the 0000-3FFF with both "00"s and "FF"s. Does anyone have any ideas? I could still use a stacked BIN someone else is using just to test it out...
Old Sep 21, 2004 | 02:53 AM
SMasterson's Avatar
Car: '89 GMC Pickup
Engine: 383 SBC Stealth Ram
Transmission: 700R4/VIG 3200
Name your 16k bin files, (know good binary files) 1.bin and 2.bin
Open Notepad, copy and paste this in it.
copy /B 2.bin+1.bin 2chip.bin
pause
Save it as filename 'stack.bat'
Click on stack.bat and it will creat a file called 2chip.bin
Burn that to your 256k BIT chip and you will have two identically
stacked files for a total of 32k BYTES.
HTH
Old Sep 21, 2004 | 07:25 AM
SBNova's Avatar
Have you tried to run the 256 chip "stacked" without the bin trader? That would rule out the bin trader as the problem.
Old Sep 21, 2004 | 08:50 AM
Car: 1997 Corvette
Hmm I jumpered pin 27 to the MEMCAL and left the switch in the neutral position, and I got my car to start. The fan still turns on right away, but the CEL doesn't stay on... That was last night. I'll probably go out in a little bit to try some more messing around with it. That was with a 128 chip. I'll try the 256 chip again when I go out there.
Old Sep 21, 2004 | 09:45 AM
Car: 1997 Corvette
Well somehow it worked just fine now. First I tried one of the 256 chips I burned last night at 4000 with the first half blanked. Then I just burned the same stock bin twice on another 256 chip and popped that in there, and the switch works perfectly. No idea what could've been wrong, but its better now! Thanks for your time guys.
Old Sep 21, 2004 | 05:28 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
It very well could be that your switcher doesn't need the "Reversed" order that other switchers (moates) do.
With moates, position 0 is loaded at the top of memory (highest address), with position F at the beginning of the chip.
I know some switchers are the other way - bins are stacked in order. position 0 starts at address 0.
Currently you cannot specify stack order in tunerpro explicitly, but you can certainly just think of things backwards in the table. Load position 0 to the top in TunerPro's binstacker.
I'll add the ability to reverse stack order in the next version.
Old Sep 21, 2004 | 09:42 PM
Car: 1997 Corvette
No worries, it wasn't a software issue. Was hardware, one of the pins was only making intermittent contact in the ZIF. Remedied
Old Sep 22, 2004 | 06:52 AM
SBNova's Avatar
Duronclocker- I guess you didnt see it above- where did you get this switcher you have. I searched and came up empty on Ebay. Do you have pics or links?
Old Sep 22, 2004 | 07:32 AM
Car: 1997 Corvette
Oh sorry I answered it in the other thread. I bought an ALDL cable from someone on eBay and he offered me a bin switcher thing for like $7-8 so I figured I might as well grab that too. I think I'm going to email him and get the bin switcher for the 512k chips for when I convert to SD/730.
Vojtush31
Oct 11, 2015 01:07 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
TheExaminer
Sep 7, 2015 08:34 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
