730 idle speed question, & TPS V vs. %
Old Nov 4, 2004 | 01:51 PM
crazyd's Avatar
Car: 1988 Fiero GT
Engine: ZZ430 Ram-Port
Transmission: 5-speed M282, SPEC Stage III clutch
1. 1992 '262 ECM (aka '730), using TunerPro, Moates G1 & 27C256. Why is my idle table ignored by the ECM? It goes from 1300-1000, but scans with Datamaster $8D always say target idle is 800rpm and it never changes with temperature. It starts and immediately idles at 800rpm regardless. This is too low for the alternator on the underdrive pulley.
2. TPS voltage ranges from 0.55 - 4.39v. With ignition on and engine off, 4.0v is 100%. With engine running, 3.3v is 100%. WTF??
TIA
Dave
Old Nov 4, 2004 | 02:57 PM
eric305TPI's Avatar
Car: 82 ElCamino, looking for a 3rd gen
Engine: 305 TPI(427SB in progress) 730 $8D
Transmission: THM350 (Getting a 4L80E soon)
Axle/Gears: 10 Bolt w/ 2.43 gears :(
If I remember correctly there is something that needs to be changed to allow for a higher idle to be set in the chip. Please correct if I am wrong
Old Nov 4, 2004 | 04:20 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
No, you are correct. The f-body $8D code has an idle RPM limiter. It is set for 800 maximum RPM. Need to change/patch the code to allow a higher RPM. Or, change to a y-body $8D mask.
RBob.
Old Nov 4, 2004 | 07:19 PM
Section162's Avatar
Car: '90 Formula
Engine: L98 --> Ramjet
FYI, Traxion's Super-AUJP bin includes a change that bumps up the max idle RPM. I think it's changed to 1200 rpm.
Old Nov 5, 2004 | 09:42 AM
crazyd's Avatar
Car: 1988 Fiero GT
Is this the file s_aujp_v2.zip on moates.net? Can that be changed on a Moates G1 or does it have to be reprogrammed in the stock chip?
Old Nov 5, 2004 | 11:12 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Copy over your VE and spark tables from your current setup.
Make sure to check ALL the parameters so you don't have trouble by overlooking something then burn it on your 256 chip for the G1.
That file is for 700R4 trans BTW.
Old Nov 5, 2004 | 11:39 AM
crazyd's Avatar
Car: 1988 Fiero GT
I guess that won't do me much good if it is for an automatic.
Old Nov 5, 2004 | 12:09 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Probably not. Which BCC are you using?
RBob.
Old Nov 5, 2004 | 08:35 PM
crazyd's Avatar
Car: 1988 Fiero GT
BCC?
Old Nov 6, 2004 | 05:44 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
BCC?
The four letter code for the chip, it defines the calibration. Such as ANHT, AUJP, AXCN . . .
The problem with the $8D code is that each BCC also has different code. GM moved it around a little and made minor changes to it. So in order to know which byte to change to get a higher allowed idle, I need to know the BCC that you are using.
RBob.
Old Nov 8, 2004 | 08:16 AM
crazyd's Avatar
Car: 1988 Fiero GT
I don't know. Can I find it in the BIN file with TunerPro?
Old Nov 8, 2004 | 10:07 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
RBob - mine is AXYC on my 383 SuperRam setup
mdtoren
Aug 23, 2015 12:52 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
mdtoren
Aug 16, 2015 05:45 PM
perZ
Aug 15, 2015 01:17 PM
