bigger injectors and regulator
Old Jan 10, 2005 | 02:22 PM
pellmanm's Avatar
Car: 1989 GTA
Engine: 383 Fuel Injected
Transmission: Pro-Street 700-R4 by Pro-built
Axle/Gears: Moser 12 bolt w/posi
What settings do i want to adjust for running bigger injectors, i am only talking about fuel here. I am using TunerPro RT and i see there is a setting for injector flow rate @40 psi, the stock setting was at 22, what else would i need to change, or is there an article I should look at.
Old Jan 10, 2005 | 02:52 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
That's the right parameter to change, however your whole VE table may now need adjusting.....
Old Jan 10, 2005 | 03:06 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
What Vern said. Also, if you increase fuel pressure, you will most likely have to adjust the VE tables as well as the Injector Constant.
Increasing fuel pressure does make a smaller injector behave like a larger injector BUT not in a linear fashion. Increased fuel pressure tends to make a smaller injector = a larger injector at high load/high MAP (Low vacuum) but that same injector at low load/low MAP (high vacuum) will not behave as the same larger injector. It will be a little different.
So your VE Tables usually are a little different at the low MAP values when you use higher fuel pressure (rather than a larger injector).
Old Jan 10, 2005 | 05:00 PM
pellmanm's Avatar
Car: 1989 GTA
What are the VE tables listed under in TunerPro RT? Does it mean volumetric efficiency?
Are these the fuel injector constants that i also need to change:
Single Fire FI Size @40psi
Double Fire FI Size @40psi
If i have 30# injectors @ 50 psi, what should i place for a value in each of these tables.
Old Jan 10, 2005 | 05:08 PM
pellmanm's Avatar
Car: 1989 GTA
And where can i check the BLM table in TunerPRo RT? I would obviously have to collect data first, but where can i check it?
Old Jan 12, 2005 | 09:54 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
There is no BLM table. By use of a data logger or scanner, you can check the BLM value in each of the 16 FTCs. The BLMs will change as conditions change. The BLMs are updated constantly as you drive around as long as the ECM is in closed loop.
Old Jan 12, 2005 | 10:00 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Once you get some data logged and can see where (RPM Vs MAP) have trouble maintaing the "ideal" 128 value. You make the correction in the VE tables where needed and go for another data drive.
The process takes a few times to get "most" of the tables behaving correctly.
Old Jan 13, 2005 | 12:05 AM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
This guy should have a MAF car, as it's an 89. This will not have a VE table, and will not require much if any (other) calibration to return it to the same performance level. There are 2 injector contsants, though, one for double fire (normal) and one for single fire (low PW compensation (double length at half as often to get PW up to linear range and = flowrates)).
Old Jan 20, 2005 | 01:29 AM
ScreaminDeamin85Z's Avatar
Originally posted by RednGold86Z
This guy should have a MAF car, as it's an 89. There are 2 injector contsants, though, one for double fire (normal) and one for single fire (low PW compensation (double length at half as often to get PW up to linear range and = flowrates)).
so do both constants need to be the same?
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
earlpote
Sep 12, 2015 11:55 AM
lakeffect2
Sep 7, 2015 03:52 PM
Strick1
Sep 4, 2015 07:11 AM
