Bad Pocket Programmer
Old Mar 19, 2005 | 06:35 PM
slay's Avatar
Hey everyone
I have a pocket programmer
It functions correctly for the most part but it will not write.
I think I screwed up and programmed a chip with the wrong voltage.
Anyways I think I fried this chip
14 pin chip # 3906 933
Does anyone here have any experience with this? Or does anyone know what kind of readings I should be getting from this chip to determine if it is in fact bad?
Or better yet.....has anyone else had this problem and know what to look for in trying to fix it? Don't reall have the money for a new one or to get fixed but I do know how to solder
Any help would be greatly appreciated.
Old Mar 19, 2005 | 09:52 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: Bad Pocket Programmer
If you had the programming voltage too high, then you probably nuked the chip.
Try programming it with all FFs, and then hit verify. That will tell you if the chip is somewhat OK. Then try programming it with 00s. If you can do both, then *generally* it means the chip is still good.
I think there was a thread here, about a transistor that sometimes fails, in the PP.
Old Mar 19, 2005 | 10:38 PM
slay's Avatar
The chip does have all ff's as I erased it in a datarase II
It verifies fine. I did program this chip before. I am fairly certain it is the programmer.
I have a few chips that I test with and they all will not program. Although they did before.
do you know about this thread with the transistor?
Old Mar 20, 2005 | 12:09 AM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
Have you contacted Transtronics? They're really quite helpful in these situations.
Old Mar 20, 2005 | 12:16 AM
slay's Avatar
think i figured it out.
I found that other thread about the transistors.
I am gonna check them out and replace if necessary and then test with a flash chip instead of a 2732a.
less room for error there.......
I think one of them might be bad.
3rdgenkindagal
Aftermarket Vendor Review
25
Oct 21, 2015 09:32 AM
anesthes
Sep 21, 2015 10:24 AM
gta892000
Sep 16, 2015 12:40 AM
Glowsock
Sep 11, 2015 11:09 PM
ericjon262
Sep 11, 2015 06:07 PM
