ALDL scanning problem.
Old Apr 17, 2005 | 08:12 PM
GSO-91Z's Avatar
Car: 1991 Z28
Engine: 305 F TPI - LB9 - GU2
Transmission: MD8 - 700R4
While a scan is running every time I press down the break peddle I lose data connection. When I release the peddle it will re-connect and start collecting data again.
Here is my setup:
Car: 91 Z28 LB9.
Software: DataMaster 8D.
I made a 2 transistor ALDL cable. Based on the Simple ALDL to PC interface schematic in this post.
https://www.thirdgen.org/techbb2/sho...ight=schematic
I have the Ground connected to port A, Data to port M and 12vdc to port F. I have the common ground connected to the chassis.
Note: I have also changed it to get 12vdc from the cigarette lighter. And I have the same problem.
Has anyone seen this before or have a idea of what I could check next?
Thanks in advance.
Old Apr 18, 2005 | 09:22 PM
GSO-91Z's Avatar
Car: 1991 Z28
Never mind.... I found the problem.
Falcon50
Aug 22, 2020 03:26 PM
RS Reaper
Oct 17, 2018 07:52 PM
HoosierinWA
Oct 7, 2015 10:15 AM
383cam
Sep 9, 2015 06:01 AM
greenyone
Sep 8, 2015 08:41 PM
