Which "mask" to use
Old Apr 20, 2005 | 04:17 PM
buzz12586's Avatar
Car: 1988 Camaro
Engine: 305 TBI
Transmission: 5 spd
Which "mask" to use
I just downloaded TunerPro today and I had found a bin file for the L03 I have from Moates website. The thing is the only supplied mask was $6E and I was looking through the values and some of the constants look really off. I have an 88 Camaro 305 TBI so which ECU file do I need, and does anyone have it.
Old Apr 20, 2005 | 04:45 PM
Dave_Jones's Avatar
Car: 83 TA, 89 TTA, others
Engine: ZZ4 TPI, LC2 turbo v6
Transmission: several, mostly broken
$6E is TPI, not TBI. Don't use it.
IIRC, the '88 TBI ran $4D on the 1228063 ECM, while the '89-'92 TBI used $61 on the 1228846.
You can find .ecu files for either at
http://www.moates.net/fileman/
Look in the folder labeled "binary editor definitions"
Old Apr 20, 2005 | 06:15 PM
buzz12586's Avatar
Car: 1988 Camaro
Engine: 305 TBI
Transmission: 5 spd
Thanks a ton man. Now I can start tuning my L03 in practice for the 350 coming in soon.
Old Apr 25, 2005 | 04:03 PM
buzz12586's Avatar
Car: 1988 Camaro
Engine: 305 TBI
Transmission: 5 spd
Anyway I can convert from the $61 to $4D. I have an lo5 bin that I would like to load to get started with my new 350 but I don't know if that will work seeing at how it is a different mask. Is it the same size (4k)???
Old Apr 26, 2005 | 11:11 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
With the C3 TBI ECMs the mask has to match the ECM. IOW, you can't run $61 in an '8063, nor the $42 mask in an 8746. This is because 2/3rd's of the code is in ROM.
RBob.
Old Apr 26, 2005 | 01:07 PM
buzz12586's Avatar
Car: 1988 Camaro
Engine: 305 TBI
Transmission: 5 spd
Is there anyway I can convert from $61 to the $4D that I need? The lo5 bin that I was going to start with is in $61.
Old Apr 26, 2005 | 05:59 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Bring up the $61 (source) bin in a bin editor to view. Bring up the $4D bin in an editor to edit (destination). Copy the values from the source bin and enter them into the destination bin.
Between the two masks the actual calibration layouts will be very close. It will only be a matter of transfering the values from the source to the destination.
RBob.
Old Apr 26, 2005 | 06:47 PM
buzz12586's Avatar
Car: 1988 Camaro
Engine: 305 TBI
Transmission: 5 spd
Yea I figured I would have to do something like that. Thanks for all the help.
Old Apr 26, 2005 | 08:09 PM
clippjr8's Avatar
Rbob, can you elaborate on the following post and which mask's you can do the copy and paste with please? Does this work for 32 to 6e changes also? Just looking for some clarifacation on this matter. I have a 4 cly bin that has no support for it and im trying to find a way to tune this car. Thanks
RBob.
