off idle stumble
Old May 6, 2005 | 09:47 AM
devilfish's Avatar
off idle stumble
Im on my 5th chip with my new engine, its still rich.
But I noticed that when going in stop and go traffic, and you go from idle to small amount of throttel, the car stumbles a bit. (tps 0-1%)
I whent from a TPI setup to a lt1intake so I wounder if this could be AE trouble? When I go WOT fast from 2000rpm and abow I got NO hesitation. Its just on low rpms.
I dont know what tabel to work with when it comes to AE, could someone guid me right..
Thanks..
Old May 6, 2005 | 09:35 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Yes, it is AE. Tweak the "%AE change based on Delta TPS". That is for small throttle openings. The delta MAP table is for large throttle openings.
Tim
Old May 6, 2005 | 09:39 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Is it possible that you are just feeling a lack of low-speed torque on tip-in? The LT1 style intakes are known for rough idle and some surging below 2,000 rpm.
Old May 6, 2005 | 11:32 PM
devilfish's Avatar
Tim
Thanks Trax.
I got "AE delta TPS multiplier vs delta TPS" is that the right tabel to play with?
And should I increase or decrease the values in order to add or take away fuel?
Old May 6, 2005 | 11:36 PM
devilfish's Avatar
I drove a friends LT1 camaro ( manual ) and did not feel the same behavior as I experince. I do feel the lack of low end torque compared to my old TPI setup, but this "must" be something else.
cheers
Old May 7, 2005 | 12:14 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
You might not be getting the fuel quick enough. The LT1 intake has a much straighter shot to the cylinders than the TPI intake does and the initial surge of air hits the cylinders much quicker.
Old May 7, 2005 | 12:17 AM
devilfish's Avatar
So another vote for AE?
Old May 7, 2005 | 12:09 PM
devilfish's Avatar
I changed the 'AE delta TPS vs delta TPS'. That helpt alot. But I think my AE is fading away to fast, what tabel is that?
Old May 7, 2005 | 03:27 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
VE
Old May 7, 2005 | 11:45 PM
devilfish's Avatar
VE? If you mean my VE tabel I got blms of 124-128 where I
got my off-idle stumble.
Its a tabel called "AE decay factor"in tuner cat, anyone played with that?
Old May 8, 2005 | 12:00 AM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
You could be fighting the delta TPS threshold required to trigger AE. Also adding VE in the low RPMs above idle MAP isn't all that bad of an idea, since little time is spent there.
Old May 8, 2005 | 12:11 AM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
Too much timing?
Old May 8, 2005 | 12:18 AM
devilfish's Avatar
When I increased the low TPS setting in tabel "AE TPS vs delta TPS" it got alot better, so I must trigger AE somhow..
What I would like to do is to "extend" the extra "burst" of fuel. Perhaps VE is a wayto achive this. Will try that.
Next is timing..
Thanks for att the tips so far..
Grant2k
Apr 4, 2016 08:21 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
earlpote
Sep 12, 2015 11:55 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
