Why does the 02 voltage decline....
Old Jun 27, 2005 | 11:59 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
With speed as the car goes down the track, it just gradually goes down.
Is there any way to reset it in Tuner Cat?
Or... is this just the nature of the beast?
I have tried adjusting it by adding fuel % vs. the RPM's ....not the results I was looking for.
Old Jun 28, 2005 | 12:01 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The response of narrowband sensors varies with temperature, maybe that has something to do with it on a prolonged blast down the strip?
Old Jun 28, 2005 | 06:54 AM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
What sort of injector duty cycle are you seeing?
How about fuel pressure as well?
How far is it dropping?
Old Jun 28, 2005 | 08:32 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: Why does the 02 voltage decline....
EGTs will effect a stock O2 sensors output.
Also the longer in PE mode, additional fuel is needed for in cylinder cooling.
If you're using a Bosch sensor, they'll do that, just *cause*.
It's just another reason to run a WB, so you can see what's really going on, IMO.
Old Jun 28, 2005 | 11:17 AM
Dyno Don's Avatar
Re: Re: Why does the 02 voltage decline....
02 sensor= AC Delco heated
Ok, making changes to the table "PE vs. RPM's" has made a definate difference, but I was looking for a way to just add fuel where it looked like it was needed.
We just converted a MAF car to SD and he has just the opposite, 02 rise as it goes down the track.
I have compared the settings but have not run across any real differences that stick out.
What sort of injector duty cycle are you seeing? 70-76%
How about fuel pressure as well? 48#
@4000pm's in 4th 890's to 850's @4800
Old Jun 28, 2005 | 11:41 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: Re: Re: Why does the 02 voltage decline....
A time in PE or VSS compensation correction table sounds like the answer, but that means patching the code.
Now that is odd, are the burst knock setting the same?, just guessing here, as that's the only thing possibly related to what you're doing that crosses my mind.
As you crank the FP up the volume goes down, maybe you're out of pump for what your doing.
850s are considered a safe value by some of the Turbo Regal guys as being rich enough.
Old Jun 28, 2005 | 12:20 PM
Dyno Don's Avatar
Re: Re: Re: Re: Why does the 02 voltage decline....
We are both running the same pump (LT1 31gph)
It seems to like 02's in the 890- 905 range. The closer to 900 the better it runs.
Old Jun 28, 2005 | 05:08 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: Re: Re: Re: Re: Why does the 02 voltage decline....
A 240?
I run out of fuel when I was running a single 340.
You might try running a FP guage on the return line, and if you have enough fuel. Yes, on the return line, that insures that your reading reflects the pump still having an excess of fuel.
Old Jun 28, 2005 | 05:25 PM
Dyno Don's Avatar
Re: Re: Re: Re: Re: Re: Why does the 02 voltage decline....
No problem there, I checked that. I can get it to over 900 in 4th but then it is at 930-940 at the beginning.
I just thought there might be something I was missing to make the correction.
Thanks for the help,
Don>>>
Elephantismo
Feb 13, 2019 12:51 AM
327IROC85
Sep 23, 2015 12:11 AM
eustodp
Sep 20, 2015 05:09 PM
ULTM8Z
Sep 16, 2015 09:15 AM
RyanJB
Sep 2, 2015 01:27 PM
