Cold idle question...
Old Aug 3, 2005 | 11:23 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
I'm not 100% sure if this is a tuning thing or something else. Ever since my t56/HSR install I've had a funky problem. When the car is cold it will idle fine until I give it gas to back out of the garage or basically move the car at all. Once I let off the gas the idle wants to stay up there. (usually anywhere from 2k-1100 r's) As long as I'm rolling (at any speed, 1mph, or 60) it will keep the high idle. Once I come to a complete stop and wait 3-5 seconds the idle usually drops down to normal. Sometimes I have to kick the throttle a little bit to "reset" it.
Am I looking at a tuning thing here or some other problem?
Old Aug 3, 2005 | 01:39 PM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Sticky throttle?
Minimum air adjustment?
Auto to Manual trans? Should change to a manual trans bin.
Old Aug 3, 2005 | 01:44 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Originally posted by RednGold86Z
Sticky throttle?
What? Are you asking if it's the cable itself? It only happens when cold and I have to come to a complete stop for it to drop. Most times I don't even touch the throttle. :shrug:
What's that?
What are the differences?
Old Aug 3, 2005 | 03:30 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
And another thing I'm confused about. Every bin I've pulled off the net has had the injector flow rate set at 22.08lbs. The 350 ones as well as the 305 ones? I set it to 19lbs and the car runs like crap. Obviously I shouldn't set it at 19 but what gives?
Old Aug 3, 2005 | 07:51 PM
Z69's Avatar
Z69
What bin are you using?
I'm not up on 305 bins. But AXXF a 305 AT bin.
AXXC AXXD AXYC are 305 mt bins. With AXYC being the newest.
Have you been looking at 350 bins? 22 is the stock size for a 350.
There is a bin search engine link up in the stickies.
And the common bins are on DIY-EFI or Moates.net too.
Old Aug 3, 2005 | 11:36 PM
eric305TPI's Avatar
Car: 82 ElCamino, looking for a 3rd gen
Engine: 305 TPI(427SB in progress) 730 $8D
Transmission: THM350 (Getting a 4L80E soon)
Axle/Gears: 10 Bolt w/ 2.43 gears :(
Take a look at the throttle follower items in the bin, refer to the stickies for detailed info.
Old Aug 4, 2005 | 04:45 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
My TA has done exactly what you describe for years now. I have yet to figure it out. I've tried everything under the sun, including new IAC, different code mods, new ECM, etc, etc.
Let me know if you have better luck
Old Aug 5, 2005 | 01:03 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Well I replaced the IAC a few months ago which seemed to help alittle but didn't come anywhere near solving the issue ($50 down the drain).
However, with the coding aspect, I think my inexperience will make any progress I have with this very very slow.
I tried the AXYC bin (after taking a long while to find it...) It doesn't seem to run any smoother. I messed with the throttle follower and IAC steps a tad but haven't had a chance to drive it since.
Old Aug 5, 2005 | 01:15 AM
Mangus's Avatar
Transmission: T5WC
Mine did it back in the stock days, so its not a programming issue. Not sure what it is.
Let me know if you ever give up and want to sell your vert. =) I'm not too far from you.
Old Aug 5, 2005 | 02:21 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Never! This is my dream car. I've already thought about headstone dash plaques for when I'll be buried in it.
I've got tommorrow off so I'm going to try and get some tuning done and at least smooth out some other problems I'm having. Like idle BLMs at 108... Hopefully I can get to messing with this. Only problem is I can only play with it for so long, then it isn't cold anymore...
If you ever get bored and want to help a fellow thirdgenner out tuning.... I'll be nearby!
Was yours originally a 5speed?
Old Aug 5, 2005 | 08:41 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Sounds a lot like the IAC learn feature.
I have an auto and run anjf :-)
Same type of deal. Once u drive it after u start it cold, it stays higher.
Try dropping your open loop commanded idle down some, dont go to far, remember your car is still cold.
Also decrease the time and temp it takes the IAC to learn.
Make sure your TB and IAC are properly adjusted as well
All of this should help to clear it up some. U could prolly eliminate it wholey, but I would rather it idle slightly high when cold, make sure it never dives or coughs and then stalls on you
later
Jeremy
Old Aug 5, 2005 | 10:57 AM
Mangus's Avatar
Transmission: T5WC
Yes. Still is.
Old Aug 5, 2005 | 10:58 AM
Mangus's Avatar
Transmission: T5WC
Its not so much that - its that after you stop long enough (5 seconds or so) the first time after moving the idle settles back down, then is fine.
Old Aug 5, 2005 | 11:28 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
later
Jeremy
I wouldn't mind having a high idle while cold but I don't exactly think it's related to that. Everything I can find seems to point to a 900rpm idle when cold. Which it will drop to when I drop to see (the vss stops sending a signal I assume). If I'm rolling and give it gas it'll usually hover around ~1200+
I'll try messing with the learn function today as well.
Thanks for the help and suggestions guys!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
Jk_Under
Sep 8, 2015 08:13 AM
IROCtometal
Sep 2, 2015 02:01 PM
