Cool comp. ??
Old Aug 18, 2005 | 09:50 PM
RBMZ28's Avatar
Car: 87 IROC (low 12's)
Engine: 400 sbc .040 over
Transmission: 700r mod
Cool comp. ??
I've done a search and to my understanding the cool comp.spark table subtracts those values(degrees) from the timing for that particular temp in open loop only???? I've been adding to this chart to improve cold start idle(starts up fine but idles low and rough) but based on what I've read/comprehend I am taking away timing????
Old Aug 18, 2005 | 11:05 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: Cool comp. ??
Less then 400 RPM and your just using the ignition module.
The easy answer is do a data log, and watch what's happening, to see what works/ feels, best.
Old Aug 19, 2005 | 12:25 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
If Im not remember it wrong the cool temp vs SA is subtracting SA in Closed loop....atleast in the $58code.
/N.
Old Aug 23, 2005 | 01:19 PM
RBMZ28's Avatar
Re: Re: Cool comp. ??
I would but my scanner does not show timing..... I thought it was only a factor in closed loop..??? Does it subtact those values(degs.) in open loop?? t.i.a.
Old Aug 23, 2005 | 05:56 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
The scanner will show what is really going on. I am amazed that you are shooting for 11's without knowing the timing of that engine. The scanner is well worth the money.
A timing light would also give you the same information.
Old Aug 25, 2005 | 10:14 AM
RBMZ28's Avatar
Have a scanner just does'nt show timing.Have timing light but can't produce a load and use it. I suppose I could use the timing light to verifytiming when cold,change values(timing) and see if anything changes but I would have to keep them all the same(timing) so that there is no discrepency going from varying temps and load???Back to the question at hand.... do the values represent neg. timing when in open loop???
Old Aug 25, 2005 | 10:27 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The coolant compesation SA table is always in affect. Open loop, closed loop, or in between loop. The SA values from that table can add or subtract timing. The final compensation value is the result of the compensation table value minus the bias value.
RBob.
Old Aug 26, 2005 | 05:52 PM
SB406's Avatar
Car: 71
Engine: 406
Axle/Gears: 3.42 8.5" 10b
OK...
I've just been experimenting with bias, cool comp. & such as well.
RBob,
What you said makes sense. For the $42 code, tunerpro shows a warm bias and a cold bias. Does the ecm subrtact one or the other? If so, where's the breakpoint? Playing with values, both bias values seem to have an effect at operating temp (190-195 F)
Any insight?
Old Aug 26, 2005 | 08:27 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Each of these are for a different SA table. The warm bias pertains to the main SA table. While the cold bias pertains to the coolant compensation table.
RBob.
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
ndndndnd
Sep 28, 2015 08:00 AM
64goatman
Sep 9, 2015 01:09 PM
