datalogging help please.
Old Nov 19, 2005 | 12:12 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
i finally got win ALDL up and running on my pc, i can also use datamaster trial and tunerpro. i know blm's are supposed to be at 128. they are on avg 135-150 throughout all the cells, how bad is this? i dont quite understand int's. i wouldnt mind being explained that, and my o2 voltage is usually under .800
what advice can ya guys give me, i can and do burn chips, im using a stock 89 vettes chip 165ecm on 6e mask.
thanks for any and all help!
Old Nov 19, 2005 | 12:37 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Go balk to the stickies and read the "Intro" ones thouroughly.
U have a lot of mods. Your life is infitestimally easier if u learn on a stock engine(wish i could go back and do it that way :-))
Go slow and dont beat on it, play close close attention to knock and verify it on the plugs(pull them out)
That will also help you to find out whether your car is rich/lean or loading up.
Make sure everything is set right in your base bin accordingly, like Injector constant , fan temps to more or less match your t-stat range and so on.
One note before you go any further, give your engine a very serious once over. Make sure you pull the plugs and check them out, ohm your plug wires, test the coil. Ohm the injectors and any other checks you can think of. Header leaks ahead of 02 sensor, etc.
Any small imperfections now will affect your tune greatly. Tuning around a mechanical or electrical gremlin is about impossible and will cause you fits.
Search for MAF, 32B, $6E, scalar tables(only if u have a wideband)
later
Jeremy
Old Nov 19, 2005 | 12:42 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
thanks, my plugs looked good i had just pulled them out the other day, new coil, new wires, i have changed for injector constants. my fans are always on. allmy exhaust was recently done, and its ball/flange style gaskets, no leaks here.
im quite confident everything is up to par. im looking for some exactly what tables i should be messing with to bring my blm down (128 correct)?
Old Nov 19, 2005 | 12:46 AM
3.8TransAM's Avatar
Like I said.
search for what I recommended.
Also read everything under the 165 ecm section in the "Intro to Tuning Guide" up top.
Links to all options for adjusting BLM on MAF cars
later
Jeremy
Old Nov 19, 2005 | 12:49 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
huh?
Old Nov 19, 2005 | 01:09 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
do high blms mean im running rich or lean? and another question, is the optimal 128 blm an indicator of a perfect afr or what?
Old Nov 19, 2005 | 03:46 AM
Z69's Avatar
Z69
Like I said.
Can't get much clearer than that!
Go to the stickies up top.
Something you should have done weeks ago.....
128 means the ecm is not correcting the long term fuel trim.
Meaning the tables are maintaining 14.7 as the o2 sensor see's it
w/o any adjustment to the BLM.
Think about it, all your mods would do what to your afr?
Old Nov 22, 2005 | 12:56 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
im sorry but this tuning 165 ecm your telling me to find in the stockies arent covering my questions, maybe im just blind.
Old Nov 22, 2005 | 04:16 AM
Z69's Avatar
Z69
The stickies can look like a foreign language at first.
That's where the searching part comes in.
Jeremy listed a few search criteria.
Once you dig around some and keep reading the stickies things will start to click. It takes a while. Some take longer than others. Some give up....
You also need to look at the other stickies besides the 165 stuff. Some of the functions are very similar regardless of ecm. I don't recall if the BLM & Int explanation is in the 747 or 730 section. You might look at the 747 fueling.txt that Rbob wrote. It's at DIY-efi originally. Not sure if it got on moates.
Look through every directory on Diy efi and moates. Never know what you'll find. You should also go to every link in Traxion's intro. It's like doing a search on google. It leads to all sorts of tangents. But your learning along the way.
Old Nov 22, 2005 | 10:40 AM
Ronny's Avatar
your 150 BLM may be the max setting in your constants. you could be leaner still. not sure if the ECU can correct fueling if that far off in main fuel table.
Old Nov 22, 2005 | 11:19 AM
yager's Avatar
Car: 1997 Jeep Wrangler
Engine: 2.2 L61
Transmission: R150/AX15/Toy T-case
Axle/Gears: 5.29
one newbi to another,
1) read all the stickys at the top.
2) search on your specific questions and read everything.
3) read every current post on a regular basis.
The more you read and 'try' to follow along with things the easier it gets. Even if somoene is working on a completly different car/tune/setup alot of info will transfer to what your working on.
-mike
Old Nov 22, 2005 | 12:34 PM
BadDog's Avatar
I'm also a newbie, and I agree. I've been reading stickies, searching on what seems relevant here and other sites, return to the stickies and scan for other relevant stuff that I can make sense of with my growing understanding, repeat as required. The hardest thing is not the learning how to do it, but rather not letting yourself get overwhelmed and give up.
Old Nov 22, 2005 | 02:16 PM
Teeleton's Avatar
Car: 89 S10 Blazer
Engine: Built 4.3L V6 TBI
Transmission: Built 700R4
Axle/Gears: 7.65/Zexel/3.73
I think I lurked on the diy-efi list for over a year before I finally got down to trying my hand at it. Are you seeing any knock counts from that gear drive?
Teeleton
Gunner242
Dec 25, 2015 04:49 PM
jaridjohn
Oct 5, 2015 07:01 AM
ULTM8Z
Oct 2, 2015 01:25 PM
Jonesyfxr
Sep 26, 2015 02:08 AM
MitcherNeaf
Sep 24, 2015 09:23 PM
