am i blind? 7749 ecu file
Old Jan 3, 2006 | 04:40 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
i cant find a 7749 ecu file, i've searched and searched
Old Jan 3, 2006 | 04:45 PM
skwayb's Avatar
Car: 93 GMC Typhoon
Engine: 4.3L V6 Turbo Charged
Transmission: 4L80e
Upgrade to Version 4.12 of Tuner Pro and you can use the new XDF file format.
2-bar version
http://www.moates.net/files/3)%20Binary%20Editor%20Definitions/1)%20TunerPro%20XDF%20Files/1)%20General%20Motors/Custom/58RR_V14.xdf
I have a 3-bar version up on my Site at :
http://www.nwstp.com/files/paul/58_2&3bar.zip
Old Jan 3, 2006 | 07:33 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
For some reason all of the ECU files on Moates.net have been converted to an XDF format. Including the ones contributed by DIY'ers.
If anyone wants the 58RR_V14 definition file in the ECU format PM me an email address. I'll send it right out.
RBob.
Old Jan 5, 2006 | 12:00 PM
Craig Moates's Avatar
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
This was done to try and simplify and clear up confusion. If there's any content which didn't make it to the XDF format, or you'd rather have the original stuff left up there, just let me know.
Old Jan 5, 2006 | 12:12 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
WinBin uses XDFs? Might be better to leave files in the original format. Is there a converter to make ECUs out of XDFs?
The RR_V14 ECU seems to be the most complete from all the ones I have seen while searching last Fall.
Old Jan 5, 2006 | 02:44 PM
midniteplowboyy's Avatar
Car: 91-Z28
Engine: SLOW ONE
Will Tunerpros ECUs work with WinBin? The latest Tunerpro should convert it if it'll work that way. It's been a while. I think you just open the file and click "save as xdf".
Old Jan 5, 2006 | 04:14 PM
Z69's Avatar
Z69
As usual, fixing one thing confuses someone else.
Thanks for taking the time to convert the ecu's to xdf's Craig.
You might want to leave one of each mask up in ecu format.
Up to you to figure out which one.
Old Jan 5, 2006 | 07:51 PM
Car: 87 T/A
Maybe I'll do that, just open up an 'ECU Files' directory and put all the original stuff in there. I should still have it kicking around here...
InfernalVortex
Apr 20, 2021 11:31 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
KO1
16
Oct 15, 2015 05:00 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
85Special
Sep 3, 2015 04:21 PM
