Tuner Pro RT Datatracing?
Old Jan 18, 2006 | 08:33 PM
liquidh8's Avatar
Car: 1981 Buick Century Wagon
Engine: 87 GN engine
Transmission: 2004R
Can someone explain what this is/is for and how do you set it up to be useful. Thanx for any and all help.
Old Jan 19, 2006 | 11:27 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
IT IS NICE
Connect/associate your VE table definition to MAP (X) and RPM (Y) of your ADS file.
Open your VE table editing box open and then run a datalog.
The cursor will highlight the cells as your logging.
Bring up the monitor screen and set one of them to view the BLM, observe the BLM value as the log plays and adjust the cells.
Just one of many possible uses.
Setting a threshold value for a constant is easier when you can watch the value. Constants bring up a window next to the constant editor box.
The only issue I have with it is that once you do an association to an item, your files must not be moved or the association is lost.
I was not able to find the location of the "path" statement that defines the location of the ADS reletive to the location of the XDF.
For now its best to put the files into the folders below TP so they stay reletive to each other.
Old Jan 19, 2006 | 03:34 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
It's in the XDF header under the ALDL Asooc. tab (select any item and hit Ctrl + F2). Paths are stored in relative form, so as long as you have XDF and ADS in the same path relation, they can live anywhere.
Old Jan 19, 2006 | 06:18 PM
JP86SS's Avatar
Didn't look there
Thanks,
Old Jan 19, 2006 | 08:11 PM
liquidh8's Avatar
Transmission: 2004R
I think I understand. I'll have to play with it this weekend, I'll post back in a few days to let yous guys know I made out. Thanx
Old Jan 19, 2006 | 08:37 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
It isnt highlight and wont let me select it. Any ideas?
Old Jan 19, 2006 | 08:43 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Fixed issue with Function object editor - X/Y combo box changes do not allow OK/Apply
I just found this on your site. I guess i should upgrade to V.4.13?
Im one of them people that just likes to keep what ive got. No changes. Diffrent is not good.
Old Jan 19, 2006 | 11:33 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
91GTABird, i would recommend getting 4.13, it works quite well & with no problems for me so far, but if for some reason you decide you don't like it, you can always reinstall you older version.
Old Jan 19, 2006 | 11:52 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Could someone send me a datalog file, I would like to try this function and my car is not driveable....
thx/N.
Old Jan 20, 2006 | 05:56 PM
JP86SS's Avatar
You've got mail
It's an $8D file but will let you play.
Old Jan 20, 2006 | 09:17 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Nice buildup GTA.
Old Jan 21, 2006 | 02:34 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
thx..........hopefully it will be running strong this year...
I cant get the X/Y ALDL links to work on tables, or do I have to have a ALDL connected? The "select X Axis.." isnt highlighted.....
I have version 4.13..............
Old Jan 21, 2006 | 06:53 AM
JP86SS's Avatar
You must set the axis "lables" in the definition to either Integer or Floating point to allow it to work.
The datastream info is a number and has to be able to look up the value. If it is a "string" it can't work.
there's a good description in the help file.
(Magnus always reminds me of that )
Old Jan 21, 2006 | 12:11 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Finally got it working. That is something else man Love the SA Main table datatracing. BadA$$ Mag
Old Jan 21, 2006 | 12:33 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
QUOTE]If it is a "string" it can't work.
(Magnus always reminds me of that )[/QUOTE]
Note to anyone not familiar with the help file. It contains just about any answer to your Tunerpro questions. Im guilty myself of forgetting to refer to the help file first.
It contains ALOT of helpfull info.
Old Jan 21, 2006 | 09:38 PM
79_EFI_Z's Avatar
Car: 79 Z28
Engine: 383
I don't understand, I have tried every combinataion of integer floating point etc.. and have read the help numerous times, and the x and y axis aldl link buttons STILL will not highlight so that I can click on them. Where are you guys going to get this to work? I am running the most current version. I am getting irritated because I'm sure it's right in front of my face but yet I've wasted the last 2 hours trying to figure it out.
Old Jan 21, 2006 | 09:42 PM
79_EFI_Z's Avatar
Car: 79 Z28
Engine: 383
SIGH, nevermind. I just figured it out right after I posted my last message.
Old Jan 22, 2006 | 12:46 PM
Mangus's Avatar
Transmission: T5WC
The X and Y Axis types cannot be set to "string". They need to be either INT or FLOAT.
Old Jan 22, 2006 | 12:47 PM
Mangus's Avatar
Transmission: T5WC
thx/N.
Look in the news section of the front page of my site. I have a link to a $6E log file that you can use to play with the included 6E definitions.
Old Jan 23, 2006 | 07:08 PM
liquidh8's Avatar
Transmission: 2004R
ok, I've been playing with it. And I am not having very good luck. I've tried to get the main SA table and the VE1 table linked so I can datatrace. BTW, using the 7747 xdf and the _42 ads file. If I change the map to floating point, and the rpm x 100 to integer, or floating point, the datatrace on references the map, it doesn't correspond to the rpm. i.e., the map cells highlight correctly, but it is always in the 3200 rpm column. Anybody have any idea's, or maybe a snapshot or their settings?? I would be great if I could get this to work.
Old Jan 23, 2006 | 07:14 PM
Mangus's Avatar
Transmission: T5WC
You have to use a log file and ADS file that is for your appliation. Are you doing that?
Old Jan 23, 2006 | 07:15 PM
JP86SS's Avatar
"X" is horizontal, "Y" is the vertical in case that is the error.
Old Jan 23, 2006 | 07:20 PM
JP86SS's Avatar
Screen Shot of VE Table
Old Jan 23, 2006 | 07:29 PM
liquidh8's Avatar
Transmission: 2004R
Yes I am. I managed to get the MAIN SA table to work, But I am still having a problem getting my VE as % (ve1) table to work. I also got the coolant comp table to work. For some reason the rpm is reading right in the ve1 table, but the map is. The x and y axis' are right too, I opened the toolbox just to make sure I was referencing the right axis.
Old Jan 23, 2006 | 07:35 PM
liquidh8's Avatar
Transmission: 2004R
JP, my cells are lighting up like that, they just aren't going in the right rpm columns, the MAP is right.
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
What .xdf file and .ads sfile are you using?
Old Jan 23, 2006 | 07:39 PM
liquidh8's Avatar
Transmission: 2004R
here is the ads file, I added bmp to upload
File Type: bmp
Old Jan 23, 2006 | 07:42 PM
liquidh8's Avatar
Transmission: 2004R
the xdf is the 7747 from craigs site. trying to upload but I can't change the file type
Old Jan 23, 2006 | 08:28 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Let me try it on my machine and well try and see wheres our differences.
I also need a logfile.
You can jsut email me the log at Bsmith91@midsouth.rr.com if you want.
Old Jan 23, 2006 | 08:40 PM
liquidh8's Avatar
Transmission: 2004R
thanx 91GTA, you have mail. I hope I am just missing something stupid.
Old Jan 23, 2006 | 08:42 PM
79_EFI_Z's Avatar
Car: 79 Z28
Engine: 383
What is the RPM(/25) in your screenshot? I set my y axis to engine speed(did not rename it) and have no problems.
Old Jan 23, 2006 | 09:21 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Liquid, send me your Bin also. Thanks
Old Jan 23, 2006 | 09:42 PM
JP86SS's Avatar
Its just the name I gave the ADS data. Can be anything, there is no standard. As long its the RPM from your datastream its all good.
Old Jan 24, 2006 | 12:39 PM
liquidh8's Avatar
Transmission: 2004R
91GTA, you have mail again, and no, thank YOU.
Old Feb 4, 2006 | 09:49 PM
liquidh8's Avatar
Transmission: 2004R
91, any luck?? Figured I'd ask again, I still can't get the VE table to coencide with the datlog.
Old Feb 4, 2006 | 11:14 PM
JP86SS's Avatar
The problem may in in the ADS file.
I don't see any other reason why it wouldn't work. Confirm the calculations on those items are not out of the numerical range indicated in the XDF.
Old Feb 5, 2006 | 11:22 AM
liquidh8's Avatar
Transmission: 2004R
I'll try a different ads file today, I'll have some time to datalog and mess around with it. Thanx, I'll let yous guys know.
Old Feb 10, 2006 | 09:10 PM
liquidh8's Avatar
Transmission: 2004R
Well, I tried 3 different ADS files, and tried every combo of floating point, integer, string that there was and to no avail. All I get is the yellow highlighting the cells in the 3200 rpm column, They move around to the right KPA rows, but they don't highlight the correct corrosponding column. I'm at the end of my rope, any other suggestions????
Old Feb 10, 2006 | 10:37 PM
JP86SS's Avatar
I don't have a log file for the 7747. Can you shoot one to me?
I'll take a look and see if I spot anything.
I got the cells to move around using an $8D log file and changing values in the datastream so they would numerically display as if they were the correct readings from a 7747 log.
Use the minitors to show you what values are being displayed for RPM and MAP.
If they are not moving or out of the numerical range of the item, then you'll need to find out what is doing that.
Could be the XDF scale factors or the ADS calculations.
Old Feb 10, 2006 | 11:09 PM
liquidh8's Avatar
Transmission: 2004R
JP, I sent you a log file. Thanx.
Old Feb 10, 2006 | 11:19 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Sorry Liquied8, but ive been busy. Im having problems with TP RT saying that the .xdf and .ads file are incompatible.
Old Feb 10, 2006 | 11:26 PM
  #42
liquidh8's Avatar
Transmission: 2004R
no problem 91, Everybody is as busy as I am. Thanx
Old Feb 10, 2006 | 11:39 PM
  #43
JP86SS's Avatar
Fixed 'em up
The row labels in the XDF were set to read as RPM x 100 so the values were much lower than the data that was coming in.
displayed values were still calculating as full numbers, that's what was throwin' you the curve.
Old Feb 10, 2006 | 11:41 PM
  #44
JP86SS's Avatar
BTW, Is that what 160 baud is like?
YUK !
I was smacking the monitor to get the data to come out faster!
Guess I didn't know I had it so good
Old Feb 10, 2006 | 11:44 PM
  #45
liquidh8's Avatar
Transmission: 2004R
yeha, 160 baud, lol. Thanx JP I owe you big time, I guess I need a fresh input on it. I totally missed that. Thanx!! What do ya think of those VE tables?? lol, big injecters and cam got me all screwy. The data tracing should help. Thanx again
tmellott89
Oct 14, 2015 02:06 PM
djmarch
Oct 2, 2015 10:41 PM
MitcherNeaf
Sep 24, 2015 09:23 PM
rubyred88
Sep 17, 2015 02:19 PM
85Special
Sep 3, 2015 04:21 PM
