hmmmmm
Old Jan 22, 2006 | 05:19 PM
NEEDforSPEED's Avatar
hmmmmm
well im havein some probs with my chip, i put the chip in right and turn the key the check engine light flashs, i
put the chip the other way the check engine light stays on, , i resoder the G2 board i got from Moates just to make sure and looked up on his site how he had it on installed on the ecm, i know im buring the chips right, i think i some how messed up or fired my ecm, inless someones got another idea
cuz i have no clue
Old Jan 23, 2006 | 12:34 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Make sure all pins in ecm/adapter/chip are clean, straight and connect properly.
Triple check your offsets. Any one on this board has had that bite them in the butt :-)
Also, every now and than, you do nuke a chip or its otherwise bad or sometimes the bin file even gets corrupeted so u burn a garbage bin. Might want to try with a knonw pure one just to turn the key on and see if it checks out.
later
Jeremy
Old Jan 25, 2006 | 04:39 PM
what do you mean by offsets, you mean the way i stack the bins?
Old Jan 25, 2006 | 06:55 PM
jeeps2creep's Avatar
Car: Jeep Scrambler
Transmission: 4L60
UH OH!!!!!! .........Wrong question........And what ever you do dont wake Grumpy up!, LOL, LOL
Anyway here's the link to moates site to help answer the offset question. Hope it helps.
http://www.moates.net/documentation....entation_id=20
Old Jan 25, 2006 | 09:21 PM
File Size Chip Buffer Start -> End Chip Start -> End
4k (4096) AT29C256 000000 -> 000FFF 007000 -> 007FF
im useing the pocket programmer 1, and pocket programmer 2 software,
on the lower right side theres 6 boxs that say this, in order
buffer start=
device start=
device end=
hex file start=
hex file end=
hex offset=
i get confused as to what gos where,
000000 -> 000FFF 007000 -> 007FF,
i have AT29C256 proms
i get a fast flashing SES, i heard you can disable the checksum but i have no idea how,
im using C.A.Ts that's what im must familiar with, i tryed tunner pro and tryed switching the ID mask to "$AA" and "AA" saved it then burned on PP2 comes out as a 32k file, put it in the G2 shocket turn the key, same thing just flashes non stop, im getting really frustrated....
Old Jan 25, 2006 | 11:10 PM
90FormulaWS6's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: WCT5
check your soldering on the board and make sure that solder isnt joining 2 of the joints on your adapter install
Old Jan 26, 2006 | 06:55 AM
Car: Jeep Scrambler
Transmission: 4L60
Ok, first you should do what formula90 said. Check the solder joints close to make sure you didnt get any from one solder pad to the next.
After this is good and when you open your programer software, make sure you have BIN file selected at bottom left . Not hex or any of the other stuff.
Insert your chip and make sure the chip is inserted correctly and you have it selected (AT29C256) in the program, Now do a complete erase of chip, enter this in bottom right of program.
buffer start=0000
device start=0000
device end=0FFF
hex file start=this should be grayed out / so you cant enter data
hex file end=this should be grayed out / so you cant enter data
hex offset=this should be grayed out / so you cant enter data
Click "erase"
Once it says device is erased then do a "Blank Check" -top left of program button...next it should tell you device is blank and if not repeat the previous steps or make sure chip is in programer socket all the way.
Next, on bottom left of program select the "load Buffer" button and go to the file where your bin is located and double click it. It should say at bottom of program in black hi-light that this is your file that is in buffer
Now look to the right bottom side of programer software and you should see the following
buffer start=0000
device start=07000-change this from 0000
device end=0FFF
Now hit "program device"......this should only take a second and programer top box should say " device verified" .
Go install in ecm and all should be good with the world.
But just to let you know "murphy's law" has been at my house for a few months now so you should be safe but he did tell me to tell everyone HEY!, LOL
Hope this helps
Old Jan 27, 2006 | 09:05 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Ive noticed lately that there have been SEVERAL "new burn wont work" questions and everyone comes out saying "Offsets?" What is offsets?
I think a simple sticky should be make for offsets alone or just a link in the DIY PROM to craigs page delaing with offsets.
Thirdgen89GTA
Jan 19, 2015 11:41 AM
seanof30306
Jun 27, 2014 03:57 PM
Classicroute66
Aug 28, 2013 07:52 PM
Lumarus
Oct 1, 2011 02:49 PM
1991tealRSt-topGuy
Jan 24, 2002 07:05 PM
