are my oxygen sensor readings normal in mV with TunerProRT???
Old Jan 24, 2006 | 02:00 PM
bigchief's Avatar
Car: 1989 Firebird Formula
Engine: 5.7L 355 TPI
Transmission: 700 R4 with TCI rebuild kit and valve body mods
According to TunerProRT, after i recorded myself driving the car regularly, and going Wide Open Throttle with it, the oxygen sensor is supposedly reading anywhere from 17.0 mV up to 950 mV..... its like all over the place. When i open the car up, it stays in the 900 mV range.... then when i let off, it stays in the 800 mV range, then after the car slows down it jumps down to like 17 mV, and keeps jumping from 20-800 sparatically. is this normal???
i'm only asking b/c in TunerProRT when anything is bad, or abnormal, the text turns RED instead of being the normal BLACK color. if anyone can help it would be really appreciated. thank you
Old Jan 24, 2006 | 02:07 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
The 950 when WOT may be a little high, but that's based on your tune. The jumping around while normal driving is completely normal. That's the way it's supposed to work.
Old Jan 24, 2006 | 07:11 PM
bigchief's Avatar
Oh alright cool. thanks a lot.
Old Jan 27, 2006 | 09:08 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Also the red text you are seeing is called "Alarms". You can set them up in the .ads editor to alarm high or alarm low at any given value. For example:
I set my TPS% to alarm high at 62% (where i had PE set to start) that way when i was in PE mode i could easily tell by by just looking at the TPS% and seeing if it was red or not. Thats just an example. There are several other things you can do with the alarm high and alarm low option.
Old Jan 28, 2006 | 05:14 PM
bigchief's Avatar
Oh, awsome, that sounds like a really useful tool. thanks!
Old Jan 28, 2006 | 10:38 PM
LoudmouthSS's Avatar
Car: 1991 Z28
Engine: SBC
dont mean to thread jack here but what is "PE"
Old Jan 28, 2006 | 10:47 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
PE=Power Enrichment=More Fuel and Usually more timing.
Old Jan 28, 2006 | 11:42 PM
Car: 1991 Z28
Engine: SBC
ok thanks
Old Jan 30, 2006 | 11:58 AM
bigchief's Avatar
haha i was wondering that too actually LOL thanks
Old Jan 30, 2006 | 02:22 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
My 02 is around 972 at wide open throttle.
Old Jan 30, 2006 | 08:13 PM
bigchief's Avatar
hmm that sounds about the same, btw your ride looks freakin clean, also 3rd gen's freakin rock, just look at that beaut' hell, mines got 250,000+ miles and its still holding up just fine best 900 dollar purchase i've ever made
Old Jan 31, 2006 | 04:53 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Mine is around 950-1000mv at WOT.
Old Jan 31, 2006 | 07:45 PM
bigchief's Avatar
well alright, i guess this is 'normal'
Old Mar 24, 2021 | 09:20 PM
Nuke82's Avatar
Car: 1986 Firebird Trans Am
Axle/Gears: 308
Re: are my oxygen sensor readings normal in mV with TunerProRT???
I know this is an old thread, but why reinvent the wheel.
Should the O2 sensor reading be constant at idle? Mine only fluctuates 20 mV peak to peak. I've read on the net that at idle the O2 reading should have a large peak to peak voltage swings, like 0.9V. The O2 reading is the top line in the pic.
Old Mar 25, 2021 | 09:16 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Depends if feedback loop is opened or closed. A coolant temp of 160*F w/724 O2mv indicates a part throttle AFR (13.8) at an 850-RPM idle state. Either Open Loop idle, or an Open Loop tune.
- Rob
Old Mar 25, 2021 | 10:45 AM
Nuke82's Avatar
Axle/Gears: 308
I remembered last night that I still have WinALDL installed from a while back, I started WinALDL up and it shows the O2 sensor voltage oscillating as it should. I then ran TunerPro and it showed it steady. TunerPro must average the O2 voltage.
I have locked out closed loop in the past, but in that screen shot it is in closed loop. BLMs are just pegged at 108. Started doing that with the new throttle body. This engine has never run right since I put on a 52mm BBK throttle body because the stock throttle body's bearings went bad and had to be replaced. Was hoping my new Bosch O2 sensor just happened to go bad at the same time. Now that I know the O2 sensor is operating properly guess I need to start looking at other things/threads. I'll look at that part throttle thing you mentioned for sure, that would cause the running rich issue. The bin is the 6E APYM bin off a reputable site. I've compared the tune to a WT1500 tune and everything jives.
Thanks for the quick reply!
Old Mar 25, 2021 | 10:55 AM
BLM's are at 108, but the INT appears to be locked at 128, so you don't have any O2 correction which is why the O2 sensor is steady state. A 108 BLM should be a lot higher than 724 O2mv, upwards of 900mv plus. Very possible your O2 sensor is not getting hot enough. Are you running headers, 160* thermostat, or a constant fan by any chance...?
- Rob
Old Mar 25, 2021 | 11:07 AM
Nuke82's Avatar
Axle/Gears: 308
Yeah, I have the Hooker shorty headers for our cars and a 160 degree thermostat, the fan isn't constant though, I actually haven't adjusted the fan parameters, they are still stock at 226 on and 221 off.
Old Mar 25, 2021 | 11:09 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Might try a acdelco afs74
Old Mar 25, 2021 | 04:24 PM
Nuke82's Avatar
Axle/Gears: 308
I'll give it a try, just ordered the acdelco afs74 and plug,
Old May 5, 2021 | 04:48 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
update? how did this new heated O2 work out ?
Old May 7, 2021 | 04:01 PM
GeneralDisorder's Avatar
They work great if you have problems with dropping into open loop at idle in cold weather, etc. Had one when I was still using a stock/modded-stock ECU (yuck).
GD
Peter Bowen
Feb 11, 2020 06:34 AM
avro206
May 10, 2008 06:37 AM
Ronny
May 25, 2004 03:31 PM
1987gt
Jun 8, 2003 08:39 AM
firbird
Feb 17, 2002 11:10 PM
