anyone give me some direction on next step? tuning
Old Feb 4, 2006 | 12:14 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
so i finished my tpi swap, i got a moates ostrich!! awesome product, i've tuned my idle / VE tables pretty good, the car hauls WOT but at part throttle 40-50% or there abouts i get like a flat spot like i hit a wall ease into it and it's fine, where should i be looking at to fix this? is it AE?
Old Feb 8, 2006 | 07:22 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
What do your datalogs look like?
Old Feb 8, 2006 | 09:16 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
well, i posted another message i found something strange, and i'm not sure if it's a bug in tuner pro or what, but the spark adv ref pulse would show 23.something degrees then jump to 2000 something degrees
Old Feb 9, 2006 | 04:55 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Wheres the post? That sounds like it could be real relative to your problem.
Old Feb 9, 2006 | 05:13 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Post
Old Feb 9, 2006 | 06:02 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
me looking at this would think somethings wrong with the module in the distributor
That sounds very likely to me. Im not for sure though, so i cant really say anything. Maybe someone else will finally chime in though.
Old Feb 9, 2006 | 08:28 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
mangus replied, it's a bug in tunerpro.
Old Feb 10, 2006 | 01:11 AM
Z69's Avatar
Z69
What his answer means in terms of your SA.
It's a small negative number.....
Are you getting knock counts at the same time?
Old Feb 10, 2006 | 05:08 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
yes knock counts, and it shows knock retard degrees, i need to run more datalogs, i'm new to all of this, so as of now it seems when i get the spark retard, i find this "flat spot" or wall, next weekend i'm going to start with the $58 code though, as i ordered the procharger
GTAman
Mar 15, 2019 11:40 AM
Cornholio7979
Sep 20, 2018 02:31 AM
xbmx89
South Central Region
Oct 31, 2015 10:59 AM
crazynights
Aug 21, 2015 06:53 AM
