ECM application
Old Mar 5, 2006 | 06:21 AM
83greencj7's Avatar
Car: Jeep CJ-7
Engine: AMC 360
Transmission: TF 999 auto
ECM application
The system I got for my CJ-7 has a 16144288 ECM. The guy told me this was used for some V8's but the only place that says they were used for V8's is on Jonas Bylands site. When I look up parts for those models they all list a different ECM. I know the chip runs things but I was drawn to the GM EFI for the limp home feature. It is installed on a 5.9 litre and I am concerned how it will run in limp home mode.
Your thoughts please.
Old Mar 5, 2006 | 08:55 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: ECM application
A0 16144288 91 - 92 4.3L S-10 & C/K Truck
The Mask, ie code that it runs is the A0, MY 91-92.
If I'm not mistaken, it was for manual trannies only.
Old Mar 5, 2006 | 08:38 PM
90RS305's Avatar
Car: 96 Silverado/99 Suburban
Engine: 700 cubic inches of 'Muican Awesome
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
Moved
Old Mar 6, 2006 | 05:06 AM
83greencj7's Avatar
Car: Jeep CJ-7
Engine: AMC 360
Am I correct then that the limp home program will not be the right one for my 360? What are my options?
Old Mar 11, 2006 | 11:02 AM
Bill usn-1's Avatar
Car: IH Scout
Engine: 345 V8 TBI
Transmission: 727
The only thing I know about the 4288 is that is what I select to view my 16136965(caprice V-8) on WinALDL.
Given that it's a C3 and hardware wise they are all about the same...I would swap to something more user friendly.
I currently swap the 6965 with my 7747 using the same harness. I have the IAT still wired in so i can also pop a 1228746 in.
I don't run the 6965 because the software support isn't that avail (other than tunercat).
So until I buy that I just stick to my 7747.
But I would not think running a 360 on a 4.3 bin would be a good idea.
I know the limphome chips are different in the 7747 from 4,3 to v-8.
I do run the 7747 on 4cyl's (which the factory never did) using the V-8 limphome chip.
Works so far!!!
HTH
Old Mar 11, 2006 | 12:30 PM
83greencj7's Avatar
Car: Jeep CJ-7
Engine: AMC 360
The guy that sold me my systen has agreed to solder the limp home chip from a 7747 into my ECM. I have had no problems but the limp home feature is one of the great things about this setup.
Thanks for the input.
Old Mar 12, 2006 | 11:28 AM
Bill usn-1's Avatar
Car: IH Scout
Engine: 345 V8 TBI
Transmission: 727
I assume you are doing all the tuning yourself?
You are looking at modifying a bin file that was designed for the 4.3 and using it on your 5.9.
You could probably take most of the parameters and copy them over from a 5.7 bin but in the end you will have a 1 of a kind ecm that if it fails, you can't go to the store and get another.
I would think that the $20 it cost for a V8 1227747 would be worth it to have something easy to replace!
Just get an ECM from a 350 motor and plug it in.
Get your system operational then start working on tweaking it.
my .02
Old Mar 12, 2006 | 01:39 PM
83greencj7's Avatar
Car: Jeep CJ-7
Engine: AMC 360
The kit was bought from Customefis and included the tuning. The reason he stated for using the 1614428 ECM was that it was a better ECM with features that most others do not have. He has modified the calibration to work with my 360. When I mentioned my concerns about the limp home chip, he finally agreed to do as stated above. He is also going to modify a spare ECM for me at a reduced price. I am also trying to get more familar with things so I can fine tune it further myself. I am sure I will need some help with that as I go along.
Once again thanks for the input and any further input will be greatly appreciated.
One more thought - is the 1227747 a direct replacement? Will it plug into the same harness?
Old Jul 10, 2007 | 03:15 PM
1badz71tahoe's Avatar
Re: ECM application
According to BillNS1 it is a direct plug in, but let me check on my 305 caprice when I get home. I have a 350 v8 ecu and my 305 is modded anyways, so it might even run a smidge better.
- B
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
