ALDL cable help (i searched)
Old Jun 19, 2006 | 04:36 PM
sting's Avatar
Car: '87 TransAM
Axle/Gears: 10 bolt 3.23
Bought a somewhat cheap ALDL cable off of ebay. thought something was up when he didnt show a pic of the other side of the connector, only the serial side. anyhow, one side has a serial connector, the other has a black and red wire coming off of it. inside the serial connector is i think 2 little transistors. I tried sticking the red and black wires into the A (black) and E (red) plugs on the ALDL port, loaded up winaldl (win95 laptop) and tried giving it a go. com port 1 says ok, and it looks like it's refreshing but everything is blank except for CT which says 106 all the time. i also tried putting it on all ECM types just to see what would happen. the diagram he sent me looks like this:
EXCEPT the R2 does not goto a 12+ it goes to pin 4 on the serial connector, is there something wrong with that? it has no cigarette light adapter for power like i've seen on some others, any help appreciated
Old Jun 19, 2006 | 08:03 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
I never had any luck getting the two transistor cable to work. The Diagram you posted is what I used whan i made mine. I think that the self powered cable doesn't alwasy work with every ECM.
In any event, you have all the parts in front of you, and with a little soldering you can have a working cable, just follow the diagram you posted.
Old Jun 19, 2006 | 10:31 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Some cars had the data line on the "M" terminal of the ALDL connector instead of "E".
Its the pin below "A".
Not sure which cars had it that way.
Old Jun 19, 2006 | 11:00 PM
Toehead's Avatar
Hopefully that's it. That way he doesnt have to do any extra work.
Old Jun 21, 2006 | 04:27 PM
sting's Avatar
Car: '87 TransAM
oh, you know what. we didn't even pick up on the fact that there needed to be a jumper between B and A. Paperclip worked, got a 10k resistor that puts her in ALDL mode. I believe she idled a little higher when I turned the car on in ALDL mode, but i'm not sure. winaldl doesnt have a closed loop flag checked, thats interesting. what other programs are available for windows 95? (old laptop)
Old Jun 21, 2006 | 06:45 PM
Toehead's Avatar
It will idle higher in ALDL mode.
Sorry about not picking up on that, should have been the first thing I suggested lol.
Old Jun 21, 2006 | 09:15 PM
sting's Avatar
Car: '87 TransAM
yeah i've done a little searching and noticed people have gotten higher idles with ALDL mode
let me get something straight, with a paperclip jumped in there, you're not supposed to start the car? with ALDL you can? is factory test mode anything important?
one last thing, someone explain to me the difference between 165 and 8192 (and a bunch of other numbers that begin with 8)?
do i have both? can i use either? ive seen references to these all over when looking through ALDL threads
thanks for the replies
Old Nov 26, 2006 | 09:37 PM
blackbeauty's Avatar
Car: 1989 Trans Am
Engine: 1989 305 TPI
Transmission: 700-R4
Axle/Gears: 2.77 10 bolt
I'm about to start data logging myself, and was wondering what you did about starting the car with the ALDL cable. Did you start the car, then plug the ALDL cable in? Or, did you plug the cable in first, then start the car?
Old Nov 28, 2006 | 12:58 PM
1991ON20's's Avatar
Car: 91 RS, t-topped, man trans.
Engine: 350cid 350Hp crate motor
Transmission: t5 with new stock clutch and parts
Axle/Gears: 3.08 stock -RS
i have a really recent model laptop......where can a get a aldl cable that has a USB cable on one end?
Old Nov 28, 2006 | 05:03 PM
extreme 1's Avatar
Car: 1989 gta
Engine: 350 tpi
Transmission: 700 r4
ALDL Cable.com has some with usb!
wigmobile
Feb 26, 2025 02:56 PM
Veaceonee
Sep 29, 2016 08:15 PM
WejaZ28
Oct 3, 2015 07:38 PM
sahlomonic
Sep 20, 2015 07:15 PM
corey8084
Brakes
Sep 15, 2015 08:14 PM
