tunerpro question
Old Jun 24, 2006 | 08:00 PM
wake77's Avatar
tunerpro question
i'm using tunerpro for aldl and i want to work out duty cycle
i have the pulse width in the stream and i can use the formula
dutycycle= pulsewidth x rpm /600
but i can't work out if i can use an equation like that in the aldl setup
any ideas?
Old Jun 24, 2006 | 09:19 PM
ty1295's Avatar
any ideas?
The current tunerpro version can't do math on 2 different ALDL values which is what you are wanting to do.
I have heard in the future it might be able to.
Old Jun 26, 2006 | 10:44 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
Indeed, it's coming. I've even got a "fuel economy" item working great in my test application (dependent on PW, RPM, MPH, and injector constant). =)
Old Jun 26, 2006 | 10:54 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Thats so cool!
Tunerpro is a great application. Once I make some more money I'm buying the ostrich and registering it.
Old Jun 26, 2006 | 10:58 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Oohs and Ahhhs..
And the crowd goes wild !!
Old Jun 29, 2006 | 12:30 PM
Mangus's Avatar
Transmission: T5WC
Here's an image (a peak of sorts) of the test app, which will be released as a stand-alone datalogging and monitoring application. After I release it, I'll integrate all features into TunerPro v5.
In this screenshot, you can see how a fuel economy item is defined (i.e. how output from items are linked to create a new item) and the results as outputted in a new analog gauge control I just finished yesterday.
This gives you a hint of some of the cool features of the new ADX ALDL definition format. It's as powerful as the XDF format is, if not more.
M
Old Jun 29, 2006 | 03:40 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Now that's really cool, Mark!!!!
Old Jun 29, 2006 | 03:53 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Looks good. New file format???? ADX???
Old Jun 29, 2006 | 03:59 PM
Mangus's Avatar
Transmission: T5WC
;-) Think XDF, but for data acquisition. (Yes, there is an ADS importer).
- new command types (listen for silence, listen for chatter, etc)
- command macros (link commands to other commands, etc)
- Item output linking (like the above example)
- constants (like the injector constant in the above example)
- calculated output can be passed to a lookup table
- string lookup tables supported (for things like outputting "High" if value > X)
- completely configurable histograms
- completely configurable dashboard
- completely configurable "list views" where defined items get added to a list view, bolded, colored, etc.
and more over time (I have lots of item types that I plan to add post-release, such as "state" items, where you can specify that a state is TRUE if MPH > X, load < Y, and overdrive == true).
Good stuff, and all working. I'll let you know when ScannerPro is ready for alpha testing.
M
Old Jun 29, 2006 | 04:14 PM
vernw's Avatar
I'm willing to help Beta that....
Old Jun 29, 2006 | 07:16 PM
Toehead's Avatar
Looks excellent! If you need public testers, i'll be willing to help (maybe testing the 160 baud support? )
Old Jun 29, 2006 | 07:28 PM
JP86SS's Avatar
Looks good! Can't wait to try it.
ScannerPro ?, kind of plain ya know.
Why not "MagnuScan Pro" !!!
Yea, I know
Old Jun 29, 2006 | 11:04 PM
Z69's Avatar
Z69
Mark, Vern is an excellent tester.
He can be very helpful for filling in the holes in your info and help files.
I think he helped on about 25% of the WB patch info file.
I mean that in a good way Vern...
Old Jun 29, 2006 | 11:42 PM
Mangus's Avatar
Transmission: T5WC
I don't doubt it. I'll make an announcement when I'm ready for testing. =)
Old Jun 30, 2006 | 09:01 AM
69 Ghost's Avatar
Car: 69 Camaro
Engine: LS1 converted to LS6
Transmission: 4L70
Axle/Gears: 12bolt 3:42
Mark, any esimate on the release date? I am interested and will test also.
Old Jun 30, 2006 | 10:53 AM
vernw's Avatar
I know you do, Scott - and thanks!!!
Old Jun 30, 2006 | 11:15 AM
skwayb's Avatar
Car: 93 GMC Typhoon
Engine: 4.3L V6 Turbo Charged
Transmission: 4L80e
Yah Mark has some killer stuff coming that is for sure. I checked out a version to see if I could get it to connect to the 749 (code 58/59).
I was playing with this nice little historgram I made when I got it to connect.
Old Jun 30, 2006 | 12:30 PM
Mangus's Avatar
Transmission: T5WC
We've pretty much hijacked the thread. Sorry!
No ETA. My ETAs are almost always way too optimistic anyway.
I've got 3 major work items left, each will cost about a full week of dev time (meaning 40 hours each). They are:
- writing the new datalogging engine
- writing the new monitor visualization (multiple items on one chart, range selection, log markers, etc)
- finish the dash (2 more controls to write, plus the dash itself)
Then I have to integrate everything and hook up the logging, write a UI for the logging (with features like search for min, max, XXX, jump to marker, etc).
So it's a bit out. I'd *like* to have something before the end of the summer, but we'll see.
Old Jun 30, 2006 | 12:31 PM
Mangus's Avatar
Transmission: T5WC
You've got to fix your axes, man! =) Also, I've since added 3D graphing for the histos.
Old Jun 30, 2006 | 03:53 PM
Duts87ss's Avatar
Car: 1987 Monte Carlo SS
Engine: HSR 383 AFR180/268XFI EBL
Transmission: 200-4R, Edge 2800 L/U
Axle/Gears: 7.5/3.73/PowerTrax No-Slip
So, is ScannerPro going to be just a stand-alone scanning software, or will it also be a tuning tool like TunerPro/replacement for TunerPro?
Old Jun 30, 2006 | 04:17 PM
Teeleton's Avatar
Car: 89 S10 Blazer
Engine: Built 4.3L V6 TBI
Transmission: Built 700R4
Axle/Gears: 7.65/Zexel/3.73
HTH
Teeleton
Old Jun 30, 2006 | 04:37 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Real time 3D graphs? As in 4D. That is looking nice and I like the ADX features. It seems to have it's own programming language built in.
Can the ALDL stream definition be defined in the file? So new ALDL modes could be added. I would like to try making a new mode to report a different set of 63 bytes. With the compiled modes I can't command the new modes right now with TP.
Old Jun 30, 2006 | 04:57 PM
skwayb's Avatar
Car: 93 GMC Typhoon
Transmission: 4L80e
I made that before you told me how to fix it and that was the only screen shot I made.
Old Jul 1, 2006 | 12:20 PM
Mangus's Avatar
Transmission: T5WC
Yes, macros will allow mode 4, etc. That isn't yet functional, but it will be.
Cornholio7979
Sep 20, 2018 02:31 AM
89fast5oh
Sep 27, 2015 09:04 PM
beast94
Aug 20, 2015 06:44 AM
redmaroz
Aug 16, 2015 11:40 PM
tmellott89
Aug 16, 2015 02:58 PM
