pocket programmer
Old Jan 22, 2001 | 08:53 PM
blowen90ta's Avatar
pocket programmer
i now have aquired all the parts to burn proms the pocket programmer,datarase,and 10 27c256 chips to start out all i want to do is burn and read a chip that i have downloaded and changed the injecter constant(using tunercat)and just play with the burner until the snow melts.the ? i have is this
using fileprom i set the chip and select to burn from file then it asks where file is located so i enter file location such as c\mydocuments\first.bin then enter it always says file not found what am i doing wrong?
thanks
pete
1990 Trans Am,350 TPI(L98),WS6suspension ,bridgestone RE71's /245/45/zr16
paxton supercharger,afr heads, alston sfc's,msd 6AL-BTM,
8.5 superconductor wires SLP 1-3/4 headers,duel cats,3"slp exaust, lakewood LCA's,T.B.Bypass
160 degree stat,alum driveshaft,fiberglass wing, secret mods
"if you cant win fair CHEAT"
Old Jan 22, 2001 | 09:32 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
The problem is that Pocket Programmer is a DOS program and having problems with the directory name greater than 8 bytes long.
I created a directory called "BINS" within "EPROM" that Pocket Programmer uses.
So I just type \EPROM\BINS\ Exactly like that AND remember to end it with a "\" too or it will think it is a file (For a lot of people it has been a long time since they worked with DOS...or they never have...its a good way to see how old someone is).
Then it will display all the bins in that directory. I just move my bins from my "working directory" to the C:\EPROM\BINS\ directory prior to leaving Windows and restarting in MS-DOS so I can use Pocket Programmer.
LC2 TECH
Interior Parts Wanted
Jan 27, 2016 08:38 PM
86IROC112
Nov 7, 2015 06:50 AM
randy210
Oct 15, 2015 03:43 PM
-=Z28=-
Sep 24, 2015 10:21 AM
anesthes
Sep 21, 2015 10:24 AM
