Need help getting a chip burned for less than 200 bucks, new miniram 383 runs badly
Old Jan 26, 2001 | 04:23 PM
Wayquick4u's Avatar
I just finished getting my 85 vette running with its new setup. It went from bone stock to a 9.6:1, 383, AFR 195CC Stage 3 ported alum heads, TPIS Miniram, 58MM T.B, 1 3/4 hooker long tubes, 1.6 rockers, 230/234-.530 actual lift hydralic flat tappet cam, built 700r4, 3.07 gears (im keeping these). I broke in the cam on the car with 19 lb injectors. the car came stock with 24 lb injectors (only 85 vettes came with this). I cannot get the car to run worth a crap with this setup. If i turn the fuel press up it blows black smoke at idle but will rev up. If i turn it down somewhat the car runs better at idle, no black smoke but it cuts out badly when you smack the gas (like no fuel). I cannot afford the 500 dollar chips of www.fasterproms.com from jim formata. Any ideas on how i get a custom chip for under 200 that will make the car run like a dream?
any ideas please email me at aidan130@hotmail.com or reply
Old Jan 26, 2001 | 04:29 PM
Blade's Avatar
You can try Ed Wright. I think he charges 150 for a custom chip.
92 Z28 L98 350
Ported stock heads, XR270HR-10 cam, TES headers, Crane AFPR, Flowmaster catback, MSD ignition components, #24 SVO injectors.
Best ET 13.3@107 mph
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
Click here to see my car at Truspeed.org
Check out TruSpeed at http://www.truspeed.org
Check out the Bin Archive at http://www.truspeed.org/bins.html
Old Jan 26, 2001 | 07:41 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Sorry to break the bad news to you but JIM FORMATO passed awaay. It will be 1 yr on Feb 6th. His wife and son still do chips though,
Here is the # (813)253-0961
I lived down the road from him in Tampa. He is the one who helped me with my chip and tuning of the Z.
he has one bad *** vette let me tell you.
Great Guy, great work. Will be missed thats for sure. He also did work for TPIS befor they started doing there own chips.
Chris
1992 25th Anniv Z28 W/383 Stroker
536 RWHP 569 FT LBS
(chassis dynoed at Ramsies Perf.)
www.go.to/TPI383
[This message has been edited by TPl383 (edited January 26, 2001).]
Old Jan 26, 2001 | 08:10 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
I think performance resource sells their custom chips for $250. Ed Wright is $350.
http://www.jetchip.com/ http://www.breathlessperformance.com/ http://www.kcspeed.com/ http://www.superchips.com/
Go here and look under links: http://www.racer-x.f2s.com/
[This message has been edited by 89gta383 (edited January 26, 2001).]
Old Jan 26, 2001 | 08:37 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
For all the money you will end up spending, why not get into prom burning? In the long run, it is the cheapest alternative and you can do SO MUCH MORE!
Old Jan 27, 2001 | 05:58 PM
Wayquick4u's Avatar
im very interested in prom burning but when you all start talking "pump shots" and all the technical stuff, how do you learn how everything works and what does what?
Old Jan 27, 2001 | 11:26 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
I know you said LESS than $200 but go with Ed Wright if you buy a custom chip as opposed to burning!! Ed will work with the chip to make it run right for you if it doesn't when you first get the thing! B'sides...his company was the winner of the '97 custom chip "shoot out"....it can't be all that bad! Check it out ----> http://www.fastchip.com
1986 Trans AM
305 TPI
4 Wheel Discs
9 bolt Borg Warner Rear
Completely Stock
Soon to upgrade to a 383 stroker w/TPI, Hedman Shorty Headers, 64cc Pocket Ported Worlds Product Sportsman-II heads, ported intake, comp cam, TPI air foil, Adjustable Fuel Pressure Regulator, possibly bigger injectors!
Current project: Keeping my car running until I get the money for the above mentioned project! :-)
Old Jan 28, 2001 | 05:01 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
In a nut shell you experiment.
You don't have to start with knowing everything. I've been at this for years and still learning. Think of it as an evolving learning process. once you start getting close then you'll want to split hairs, and get picky about things.
Like walking just get the basics down first, try a lil timing then move the fuel around, once you get the basic timing and fuel right then worry about the finer points.
Frozer!!!
Jan 19, 2024 04:55 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
86IROC112
Aug 17, 2015 02:00 PM
Bradsaundry
Aug 12, 2015 12:34 AM
Exxon Limited
Aug 9, 2015 08:13 PM
