Engine swap - do I need a custom chip?
Old Jan 30, 2001 | 08:13 PM
Maverick13's Avatar
I've got an 89 305 TPI 5spd and am putting in a 350. I understand I'll need a prom chip for my ECM. I've looked around and cannot seem to find a chip for a 350 TPI 5spd, all the chips are for autos (I guess since GM didn't make any 350 5spds due to the weak T5). Can I just use the 350 chip or do I need a custom burn?
I've read all the DIY burning vs. pre-burnt commercial threads. I know that a DIY chip will out perform any of the commercial ones, but for the time being money is REALLY tight (cuz of the new engine and tranny). So for the time being can I make due with a commercial chip (ie. make it work w/ the 5spd), run my old chip, or do I definitely need a custom chip (either DIY or taking my car to the shop and overpaying for someone else to dyno the car, burn the chip, etc)?
Thanks!
Maverick
1989 Formula 305 TPI 5-speed
Suspension mods, stock engine
Old Jan 30, 2001 | 08:29 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Simple, you either can take a 350 auto chip and change the switch to "Manual" from "Auto", or modify your existing 305 chip for the extra displacement and larger Injector Flow (you are using 22# injectors aren't you?).
I feel that manuals have slightly different "needs" than an auto and if I was in your shoes, I would make the adjustments to your 305 BIN and then "tweak" the VE tables and Spark Tables.
Old Jan 30, 2001 | 08:57 PM
Maverick13's Avatar
I'm not sure if I'm gonna use the 19lb injectors from my 305 or if I'm gonna upgrade to 22lb.
Anyway, to change the switch over to manual do I need the prom burning equipment or is there a physical switch on the chip (sorry I'm a beginner). If so, I don't have the means to do this at the moment.
Maverick
Old Jan 30, 2001 | 10:37 PM
87Z-ya's Avatar
The 350 auto chip will work fine. The difference is in the way the iac is used to keep the revs up between shifts. Im using the 350 chip thats in the tech section for a 87 350 for my setup and it works ok. And glenn is right the 5spd has diff fuel and spark curves, but the 5spd had a diff cam then the auto. If your 350 is stock I would just spend the 40 bucks on the gm 350 prom for your year. And bump up the pressure or switch to 22 or 24's
87z 383,afr 190's, crane hyd roller(224/230-.509/.528,112 sep),Ported and polished mini ram, 30lb inj, 3.42 gears, strange 12 bolt, tremec 5spd, , 1,3/4" slp headers.
[This message has been edited by 87Z-ya (edited January 30, 2001).]
Old Jan 31, 2001 | 12:22 AM
Blade's Avatar
What "tech section" ??
92 Z28 L98 350
Ported stock heads, XR270HR-10 cam, TES headers, Crane AFPR, Flowmaster catback, MSD ignition components, #24 SVO injectors.
Best ET 13.3@107 mph
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
Click here to see my car at Truspeed.org
Check out TruSpeed at http://www.truspeed.org
Check out the Bin Archive at http://www.truspeed.org/bins.html
Old Jan 31, 2001 | 01:21 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I'm using my 91 305 5-speed chip with my 350 engine. I'd say keep it.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Jan 31, 2001 | 05:19 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Thanks!
Do you want it right?.
Or is well with the key it starts?.
I'd start with a manual memcal, and then use the 305 calibration and modify as neseccary.
Kinda a PITA, but if your wanting **right** thats my 2 cents
Old Jan 31, 2001 | 05:51 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
I have a 350 auto chip in mine runs good but, I know It can do way more!
Old Jan 31, 2001 | 08:42 PM
87Z-ya's Avatar
https://www.thirdgen.org/newdesign/faq/thirdgen.shtml
faq section, my fault.
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
theshackle
Mar 5, 2017 06:37 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
