Changing from 32 to 6E
Old Mar 19, 2001 | 12:35 PM
87IROC350's Avatar
Engine: 5.7
Should you use an 89 memcal or can you use an 87 memcal with no problems when switching from 32 to 6E code?
Old Mar 19, 2001 | 12:39 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Either Or.
As long as the MemCal was designed for the 165 and a TPI vehicle with similar options (tranny, eng size, etc).
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's with bigger cam, bigger stall, and bigger exhaust.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
Old Mar 19, 2001 | 04:57 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Uh oh... What about using an AXXD (92 305 5-speed) memcal with a 350 5-speed?
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
Old Mar 19, 2001 | 09:35 PM
87IROC350's Avatar
Engine: 5.7
So is the gear ratio stored on the memcal or is it in the bin you use?
Also, I guess everyone with a 730ecm has had good luck using the flash proms 29C256. Any suggestions on a flash prom to use on the 165ecm? Im ordering all my stuff now and if I can find a flash prom that will work for my 165ecm I won't need the UV eraser!!!
Old Mar 20, 2001 | 02:48 PM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
87IROC350, the gear ratio is stored in neither the memcal or in the bin, at least for the '165 MAF cars. The TCC lock-up speeds are probably different between cars with different axle ratios, and maybe a few other minor things, but nothing else to signify different axle ratios. When you change gears to a different ratio, just change the speedo gears to the correct ones, and everything will be hunky-dory.
Greg Westphal
'87 IROC 305TPI/A4
billybob6110
Feb 11, 2016 10:41 AM
64goatman
Sep 9, 2015 01:09 PM
IROCtometal
Sep 9, 2015 10:01 AM
FormulasOnly
Sep 6, 2015 10:42 AM
luvofjah
Sep 3, 2015 07:08 PM
