What is an ECU file?
Old Apr 22, 2001 | 05:02 AM
86 IROCZ28's Avatar
I am too getting into the business in programming my own chips.
Just wondering what the difference between the ECU and BIN files are. My understanding of the BIN file is the actual data stored on the PROM and when you make a copy of it on PC it is stored as a BIN. But what is the ECU file used for??
Does anyone recommend any BIN file I can try on my 86 IROC 305 TPI with 3.42 gears and a 700R4 trannie?
Old Apr 22, 2001 | 08:32 AM
Aaron's 87's Avatar
ECU is a file that translates BIN values into stuff you can use, like tables and constants. Read the article in the link at the top of the page.
Old Apr 25, 2001 | 05:45 PM
Desert86Roc's Avatar
As for what .bin to start out with... go for the ARAP.bin . Modify it for your fuel injector flow rate, disable VATS, and maybe lower your fan temps while you are at it, and you will be at a good starting point.
That's what I did, and I am lovin' it.
Mike Metzler (Desert86Roc)[*] Webmaster: SpeedWorldMotorplex.com[*] Click Here For 86 IROC 305 TPI (406 build in progress) Page
ET's @ 1250 ft[*] 14.28 @ 95.461 mph (uncorrected, NOS, no headers)[*] 15.365 @ 86.785 mph (uncorrected, headers, no NOS)
InfernalVortex
Apr 20, 2021 11:31 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
Jerzyperson
Carburetors
Nov 13, 2015 01:07 AM
KO1
16
Oct 15, 2015 05:00 PM
MitcherNeaf
Sep 24, 2015 09:23 PM
